Antenna issues
Discussion in 'CB Radio Forum' started by Drumbum, Jul 23, 2012.
  1. Drumbum
    Drumbum Light Load Member
    82
    21
    Jul 23, 2012
    I just installed a cb in a 09
    i used a new mount with a Francis 4.5ft
    when I put it on without a ground wire my swr was just over 2.1
    and I was getting out about 1.5 miles
    i put a ground wire on that connected to the factory ground strap
    and my swr dropped way down (these readings were taken off of the
    built in meter on a cobra 29)
    But now i am not getting out at all
    Any ideas?
  3. mike5511
    mike5511 Road Train Member
    3,156
    1,546
    May 15, 2011
    NW Arkansas
    09 what? Got a picture??
  4. Drumbum
    82
    21
    Jul 23, 2012
    Sorry 09 prostar. I'll take a pic
  5. mike5511
    3,156
    1,546
    May 15, 2011
    NW Arkansas
  6. Outlaw CB
    Outlaw CB Light Load Member
    260
    179
    May 26, 2012
    I am guessing he hooked the other end of the wire to the antenna hot as he does not specify with clarity. He only states "on that". This would explain the no distance comment. As well it explains the internal meter zero, ohms law would indicate a dead short on the coax gives zero volts for the meter to work with. Remember how the internal meter circuit is configured. He needs to connect the antenna end to the bracket itself not the hardware in the center.
  7. mike5511
    3,156
    1,546
    May 15, 2011
    NW Arkansas
    I wondered about that but didn't know for sure.
  8. Drumbum
    82
    21
    Jul 23, 2012
    Thanks for the replies
    I connected the ground wire from the new antenna mount to the current mount where the original ground strap is
  9. Drumbum
    82
    21
    Jul 23, 2012
    This does sound like what is happening though because my swr seems very low but the signal is not going anywhere.
  10. Drumbum
    82
    21
    Jul 23, 2012
    Well I unhooked the ground I put on and im getting
    Out now not sure how far and my swr meter still
    Reads three bars up well under 1.5 on a cobra 29lx
    Going to try new coax tonight when I get to the ts
