antenna manfactures coax requirements
Discussion in 'CB Radio Forum' started by Jolsen, Apr 12, 2010.
  1. Jolsen
    Jolsen Heavy Load Member
    951
    272
    Mar 6, 2010
    East of the big crick
    How important is it to fallow what it says for the coax the antenna manufacture recommends? I have 9ft of mini 8x ran right now. but this 5.5ft francis or however you spell it. want me to use 18ftof rg58. i really don't want 9ft of coax laying on my dash. i also dont have any kind of swr meter. i am only running a Cobra 19 ultraIII. its not the best but its getting me by till i can get my original cobra 25 from the 80s looked over and peaked and tune by whomever is the best in the usa at working on those.
  3. Carolina Thunder
    Carolina Thunder Medium Load Member
    584
    179
    Jan 28, 2007
    Coeburn V.A.
    You HAVE TO have 18 feet of coax,this is a starting point for any antenna used for the CB band. Now you can run a longer coax if you need to as long as you do it in 3 foot lengths,if you do it this way your SWR will be easier to set,other wise you will be chasing your tail with and odd length of coax. You can order a cheap SWR meter on line or find one at Radio shack. If you don't have a cb shop close to you you need to do this because if you don't and your SWR is to high sooner or later you WILL blow the finals out of your radio!
    No disrespect to you but if your not going to do the install right then don't do it at all because in the end it only its only going to cost you money and aggravation!
  4. Mad Dog 20/20
    Mad Dog 20/20 Heavy Load Member
    768
    193
    Jan 31, 2010
    Skid Row
    I was taught to use as much coax that is needed to reach your antenna, if the length of your coax effects rhe impedance of your antenna system you might have other issues.
  5. WA4GCH
    WA4GCH Road Train Member
    3,324
    577
    Aug 12, 2009
    Seminole Florida
    CORRECT .....
    You cannot tune a antenna using coax UNLESS the coax is not 50 ohms then it is acting like a matching stub ....
  6. Xcis
    Xcis Medium Load Member
    497
    269
    Jul 9, 2008
    Bridgeport, Pa
    The standard type of coax for a single antenna setup is RG 58. RG 8 is an upgrade from RG 58 ;therefore, RG 8 is a better grade of coax. A little overkill for a stock out of the box cb radio with no additional amplification but perfectly acceptable.
    The coax has to be long enough to connect the radio to the antenna. 18 feet of coax is a common myth. It is based on the 1/2 wave length of the cb radio frequency which is 18 feet. What these people fail to realize is that 18 feet is the 1/2 wave length of the cb frequency through air. We connect our cb radio to the antenna using a coax cable. The cb radio frequency is traveling through the metal wire that is the center conductor of the coax cable. The 1/2 wave length of the cb frequency traveling through metal, ie the metal wire center conductor of the coax cable, is 11 feet 10 inches. So, that 18 feet of coax cable is actually over 50% longer than the applicable 1/2 wave length of the cb frequency that travels through the metal center conductor of the coax cable being used. Okay, in plain english, the half wave length of the cb frequency has absolutely zip, zero, nada, nothing to do with the coax length. Use whatever coax length you want. If it is long enough to connect the radio to the antenna, you are good to go.
    I do suggest that any excess length of coax be fashioned into a figure "8" approximately one foot in length.
    In case someone not familiar with standing waves is reading this post now or in the future, I state the following. Not using an SWR meter to determine the standing wave ratio or SWR is, in my opinion, a mistake that can seriously damage your radio. If the SWR reading is 1.1 that is a perfect score you cannot do better. 1.2 or less is like an A. 1.3 or less is like a B. 1.4 or less is like a C. 1.5 or less is like a D.
    It is a common misconception that a SWR reading higher than 1.5 means that you need to tune the antenna. WRONG, WRONG, WRONG. If the SWR reading is between 1.5 and 3.0, you probably need to tune your antenna. However, if your SWR reading is 3.0 or higher, that indicates a CONNECTION PROBLEM. Common connection problems include breaks or shorts in the coax cable, breaks in the internal wire of the antenna, faulty antenna ground among things. If you have a SWR reading of 3.0 or higher, do not use the radio or you are very likely to damage the power transistors, commonly refered to as "the finals". Should that occur, you will be lucky to be able to transmit a quarter mile if that far. Fixing a radio with blown finals is quite expensive. Getting your SWR checked is cheap insurance and money very well spent.
    If you are a total novice to CB radio, it is time well spent to go to the local library and check out a book on CB radio. Purchasing a used book on CB radios that you can use and reference is also money well spent.
  7. Jolsen
    951
    272
    Mar 6, 2010
    so why would they say to use rg 58 at an 18' and say specifically not to just mini 8x?
  8. Jolsen
    951
    272
    Mar 6, 2010
    im just failing to understand why i they dont want me to use my 9foot mini 8x instead of the 18foot rg58. my 9foot reaches fine with no extra after i run and tuck it out of site.
  9. josh.c
    josh.c Road Train Member
    1,105
    420
    Feb 22, 2009
    Knoxville, Tn
    I think you mean higher than 3:1 in the part highlighted in red, you should edit it so it's not confusing. Calling 1.5:1 a "D" makes it sound like there's something wrong with a SWR of 1.5:1.
    "They" are telling you to use 18 feet because that's what "they" have always told them, and "they" don't know any better.
  10. Jolsen
    951
    272
    Mar 6, 2010
    they being the antenna manufacturer. i figured they made it. so they must know best. cause i was just like what does it matter if i use a 9 ft instead of 18foot. and i like my mini 8x its all silver and chrome looking.
  11. Big_m
    Big_m Heavy Load Member
    881
    265
    Oct 13, 2009
    Central Maryland
    Some Manufactuers made or sold coax. So maybe it was said to boost their bottom line. If your 9ft 8x works for you. By all means use it. I've run 9ft of 8x coax for years. And everything worked just fine. It's true you only need the amount to reach for antenna to the radio.
