Antenna mount question
Discussion in 'CB Radio Forum' started by Cornbread914, Apr 21, 2022.
  1. Cornbread914
    Cornbread914 Bobtail Member
    20
    15
    Apr 8, 2022
    I just bought a Stryker SR497-HPC radio. I was running a 6’ wire whip behind the sleeper, but when I couldn’t get my SWRs down under 3, I went back to my Wilson 5,000 on passenger side mirror. SWRs are better but the best I could get them was between 2 - 2.5. Question: Would it make any difference in SWR, modulation or output depending on which side of truck you put antenna??
  3. M22 rockcrusher
    M22 rockcrusher Road Train Member
    1,269
    3,955
    Nov 21, 2020
    First try..turn your rf power all the way down. Turn mic gain all the way down and turn off talk back...sometimes these causes reflected bounce back in your coax..just a thought
  4. Cornbread914
    20
    15
    Apr 8, 2022
    Ok, but if I wanna run those ON & turned up, how do I get SWRs down?
  5. M22 rockcrusher
    1,269
    3,955
    Nov 21, 2020
    I have 2021 Cascadia I run a wilson T 2000 on the driver's side I was told by someone that the passenger side is where all the electronics is and will interfere with performance of the antenna. Your just turning those off for checking swr. I have a rci 39vhp with built-in swr meter and also use a astactic meter. So if swr is too high you may need to trim it the whip some 1/4 inch at a time. If it's on a perch try moving it forward some..but it's probably best to visit a cb shop to have it checked out..that 497 has a of power to it. You want to burn up any finals
  6. M22 rockcrusher
    1,269
    3,955
    Nov 21, 2020
    Please excuse my spelling I'm all thumbs tonight lol
  7. M22 rockcrusher
    1,269
    3,955
    Nov 21, 2020
    By the way did you get your radio tuned and aligned when you bought it.
  8. Antinomian
    Antinomian Road Train Member
    2,108
    3,326
    Feb 17, 2013
  9. Cornbread914
    20
    15
    Apr 8, 2022
    I already went thru the tuning process on the antenna. I trimmed it until it started to ease back up and then raised it back up just enough to get it back to its lowest point. This is an older antenna, may need an upgrade, maybe pair it with a Stryker antenna
  10. Cornbread914
    20
    15
    Apr 8, 2022
    Yes I did.
  11. Cornbread914
    20
    15
    Apr 8, 2022
    379 Peterbilt
