Antenna options
Discussion in 'CB Radio Forum' started by BigB, Feb 28, 2012.
  1. BigB
    BigB Bobtail Member
    10
    Aurora, IL
    I have a peaked and tuned cobra 29 wxnwst with a wilson 5000 mag mount ( No power ) for my personal vehicle. I have heard various reports that the backwards sway of the stinger from highway speeds takes away from the dx/tx. Dont get me wrong I love the wilson 5000. I just recently bought a few antennas to test against the wilson to see if i can get the same results, worse results, or perhaps better. I have order the francis 5 ft, firestik (tuneable) 5 ft, and the 7 ft skipshooter. All three of these antennas have not arrived yet, so looking for your opinion on these three from the gurus.:biggrin_25514:
  3. Tricky Rick
    Tricky Rick Light Load Member
    177
    91
    Oct 25, 2010
    Northwest Mississippi
    Not even close to a guru, but I have the exact Cobra, and i use the 5.5 ft. Francis. Much better than the 4.5 or the 5 ft.. I have a K30 by K40 on my car with 1.2 SWR. Works really well, also.
  4. BigB
    BigB Bobtail Member
    10
    Aurora, IL
    Hi Tricky Rick. I had the K30, couldnt get out more than half mile. My very first antenna was a k40 mag. it was very good except the coax broke. so, went with the wilson 5k mag mount. I may use power someday. for now, i think its overkill. it works well. cant wait to see the others perform believe it or not I had the swr's on the k40 mag mount flat on all channels. the wil 5k mag is about 1.3 across the board.
  5. jessejamesdallas
    1,416
    855
    Oct 3, 2008
    Republic of Texas
    no...that wont take away from your dx/tx...Being a Base Loaded Antenna tho will make it less efficient...Center load and top-load antennas will be more efficient, or if you can get away using a 102" Whip would be best...
    I have no problems being herd, or hearing others using center loaded, open-coiled type antenna's like the Predator 10K's...
