Antenna placement...
Discussion in 'CB Radio Forum' started by Fishguy58, Jan 23, 2017.
  1. Fishguy58
    Fishguy58 Bobtail Member
    Just out of curiosity, has anybody ever tried mounting an antenna on the the front fender mirror arms on the Cascadia? Everytime I talk with a CB Shop tech they tell me something different as to why I can't receive but for a short distance.
  3. Ridgeline
    22,727
    123,496
    Yeah there is too much isolation from the body to be effective.
    bored silly Thanks this.
  4. rabbiporkchop
    9,678
    6,545
    Feb 9, 2012
    Wapwallopen, Pa
    Up high outside the rear fairings would be ideal. More mass below feed point is the goal.
  5. craig_sez
    craig_sez Road Train Member
    5,570
    2,714
    Sep 5, 2013
    novascotia,Canada
    You get dofferent storys cause they claim to know but dont..
    Problem as ridgeline said is the lack of mass(metal)to go under the ant..Metal on the side or above hurts performance..Mounting on the mirror arm like they tell ya is ok at best but still not very good..
    Ground wires to the chassie bs is not a fix either..
    Other than ridgelines dipole comment out back just off the flairings is about the best idea from what i understand..Now if you wanna stay on the morror arm and do a dipole that may do the trick for about a 5-8 mi range..
    Now if you wanna line the inside of your truck body with some sorta reflective material(metal/metal like tape) that would be cats ###..
    Not many workable solutions for these trucks..
  6. rabbiporkchop
    9,678
    6,545
    Feb 9, 2012
    Wapwallopen, Pa
    The dipole would be best if you could elevate it with your extension otherwise you'll be limited to similar range as Neverready because his is close to the ground
  7. craig_sez
    5,570
    2,714
    Sep 5, 2013
    novascotia,Canada
    Putting a big flat plate up there will catch to much wind..Will that plate i had made,is that worth useiing..
    Gonna have to go through the threads to find the proper way to install..
    Now seeing my ohm meter showed zero ohms on mounting bracket,is that in my favor at all?
  8. rabbiporkchop
    9,678
    6,545
    Feb 9, 2012
    Wapwallopen, Pa
    Stick the antenna on at a 45 and call it good. Use the longer shaft but Don't use the extension bracket
  9. craig_sez
    5,570
    2,714
    Sep 5, 2013
    novascotia,Canada
    K.thought you were telling me to go with the tall mount dipole
  10. craig_sez
    5,570
    2,714
    Sep 5, 2013
    novascotia,Canada
    What about the fact that there is no grounding from the mirror bolts??
  11. rabbiporkchop
    9,678
    6,545
    Feb 9, 2012
    Wapwallopen, Pa
    You said there was
