Antenna recommendations
Discussion in 'CB Radio Forum' started by D.Tibbitt, Dec 14, 2019.
  1. D.Tibbitt
    157,282
    I have a basic uniden pc68ltx radio. Am running 2 antennas on pete 386 . Lost one antenna the other day when ice got stuck to it and started whipping it around and eventually snapped off. Figured i would replace the other antenna as well since it looking rough.im looking for 2 antennas that wont break the bank but still give me good range. U guys have any recommendations?
  3. skellr
    skellr Road Train Member
    8,735
    12,187
    Jul 17, 2011
    The Village, Portmeirion
    Francis is a good cheap antenna.
    Francis - Fiberglass CB Radio Antennas
    Most truck stops sell them but don't buy the 3' ones. Look for a 4' one. The longer the better, not many truck stops sell the 5' one.
    I would stay away from Wilson fiberglass antennas, the wire tends to break near the base.
    D.Tibbitt Thanks this.
  4. Atlaw4u
    Atlaw4u Heavy Load Member
    750
    1,131
    Jun 8, 2018
    Anyone have experience with the Firestick antennas? I don't but I see a lot of them around.
  5. Timin770
    Timin770 Road Train Member
    1,658
    1,759
    May 27, 2011
    Canton, GA
  6. Timin770
    1,658
    1,759
    May 27, 2011
    Canton, GA
    I've had good luck with the fire sticks with the adjustable tip but skipshooter seem to be popular on this forum as well
    12 ga and D.Tibbitt Thank this.
  7. craig_sez
    craig_sez Road Train Member
    5,570
    2,714
    Sep 5, 2013
    novascotia,Canada
    Skip shooters...Go as long as you can while staying an inch or so around 13'6"....Use a cloth with wd 40 and wipe down ant and that helps with snow and ice sticking to them..
    Francis ant!! Ppppfffttttt they whip around inmthe parkin lot for cryin out loud..
    Timin770 and D.Tibbitt Thank this.
  8. D.Tibbitt
    157,282
    Gonna try out the skipshooters. Thats a great idea wiping them down with wd40 . Thankds for the advice n help
    Timin770 Thanks this.
  9. craig_sez
    5,570
    2,714
    Sep 5, 2013
    novascotia,Canada
    Had good results and when i called them one time i got awsome service to..Dont know what shops physically sell them but their site has some listings and if you dont see any,order them..
    Depending on your trucks mount point just subtract that from 13'6" and you will know how long to buy..
  10. skellr
    8,735
    12,187
    Jul 17, 2011
    You must be thinking of something else. Francis antennas don't have enough mass to start wobbling around... Seriously, try to shake it like a stick and see what happens?
    Skipshooters are good. But, what truck stop sells them when you need a replacement right now?
