antenna ????'s
Discussion in 'CB Radio Forum' started by boyd2187, Oct 16, 2012.
  1. boyd2187
    boyd2187 Bobtail Member
    36
    4
    Jan 20, 2012
    hickory,nc
    Just grounded my monkey made antenna to the. Door of my truck looks a little funny straight up why do people turn the antenna. Out how does it help
  3. MsJamie
    MsJamie Road Train Member
    "Conventional wisdom" says that by tipping the antenna forward, you are putting the bulk of the metal in the truck below the antenna, working as a better ground plane.
    While that may be true, it also pumps most of your forward RF into the road, and the rearward RF into the sky...
    boyd2187 Thanks this.
  4. STexan
    STexan Road Train Member
    14,963
    29,160
    Oct 3, 2011
    Longview, TX
    I thought they tilted them forward to withstand the sometimes grueling air speed sustained during "fast trucking" operations (70+ MPH)
  5. cadillacdude1975
    cadillacdude1975 Road Train Member
    1,081
    394
    Mar 20, 2010
    Chattanooga, TN
    the tilting goes back farther than that. i talked to a fwe old old timer drivers, and if you think about it, the pointing the antenna makes sense. they used to measure from the tip of the antenna to the ground at 13 ft 6 in and pointing it forward to see if they would clear the overpass.
  6. Big_m
    Big_m Heavy Load Member
    881
    265
    Oct 13, 2009
    Central Maryland
    The reason of the forward tilt was first done to lower SWR. When we had metal trucks the metal would sometimes cause higher SWR reading. And a slight forward till would lower it. Check it out it does work.
  7. jessejamesdallas
    1,416
    855
    Oct 3, 2008
    Republic of Texas
    Some do it because of clearance issues too...Other's do it just because they seen someone else do it, and call it "Bull Horn" mounting so they thought that sounded "Cool" and mount theirs the same way...not a good idea by the way if you don't have to mount that way...
  8. Nashv755
    Nashv755 Bobtail Member
    39
    Nov 12, 2012
    I mounted a pair of terminator 2 antennas on the factory cab mounts on the kw2000 I was driving at the time and called them my bridge finders.....
  9. murph
    murph Light Load Member
    77
    10
    Jan 22, 2010
    A lot of tri-axles in my area will run the bull horns if they are not running the shorter Firesticks.
