Antenna Stud
Discussion in 'CB Radio Forum' started by Finfn1372, Jun 21, 2019.
  1. Finfn1372
    Finfn1372 Road Train Member
    1,930
    3,599
    Aug 7, 2014
    Greenville,NC
    So i'm currently in the process of upgrading my antenna system,I have a 4ft skipshooter on a spring,with a tram heavy duty stud,on a birdperch on my volvo.
    I'm looking to maybe upgrade to a predator,but I'd like to upgrade the stud aswell.
    Can anybody recommend a good stud,or where to look for a good stud thanks.
  3. throttle325
    throttle325 Bobtail Member
    29
    10
    Apr 5, 2019
    Did you have to reroute your coax in order to bypass the multiplexer? If so, did you have to remove panels?
  4. Finfn1372
    1,930
    3,599
    Aug 7, 2014
    Greenville,NC
    Yeah I just have it running to the top of the door jam,can't do the mirror routing at this time.
    When I had my freightliner I ran it under the hood to the firewall behind the dash,but these volvo's it's just to much work to take the mirror's apart,knowining my luck as soon as I did it my company would have me switching trucks.
  5. rabbiporkchop
    9,678
    6,545
    Feb 9, 2012
    Wapwallopen, Pa
    Stud Mounts
    Method240, Slowmover1 and Finfn1372 Thank this.
  6. Slowmover1
    Slowmover1 Road Train Member
    1,491
    1,210
    Oct 25, 2015
    Fort Worth
    This is my current configuration. Back-of-sleeper on a leased 579.
    1). 5’ Skipshooter
    2). SS Wilson spring
    3). TOP GUN TEC antenna stud
    slim6596 and Finfn1372 Thank this.
  7. jessejamesdallas
    1,416
    855
    Oct 3, 2008
    Republic of Texas
    If your going with a Predator 10K...Go with the Predator 10K stud-mount...matches up perfectly with all the Predator 10K antennas since they are made by the same company!:D
    Predator Wide Banded Amateur Antennas
    Finfn1372 and Slowmover1 Thank this.
  8. rabbiporkchop
    9,678
    6,545
    Feb 9, 2012
    Wapwallopen, Pa
    Probably best to specify the
    H/D stabilizer stud with terminals since the H/D stabilizer stud with SO239 is only as strong as the 25-cent bottom half..
    jessejamesdallas Thanks this.
  9. Method240
    Method240 Light Load Member
    52
    30
    Jun 9, 2019
    TN
    you can still get the Predator stud mounts with so239 or lug connectors. like $25
    rabbiporkchop Thanks this.
  10. Method240
    52
    30
    Jun 9, 2019
    TN
    chop gave you a good choice
  11. Method240
    52
    30
    Jun 9, 2019
    TN
