Anti gel for frozen trailer air lines?
Discussion in 'Questions From New Drivers' started by Chicken wang, Feb 6, 2025.
  1. Chicken wang
    Chicken wang Bobtail Member
    24
    29
    Dec 11, 2023
    Cleveland, Ohio
    Im not a " New driver " but decided to post this in here anyway.
    Anyone ever used anti gel to free up frozen tailer air brake line in a pinch. I know they sell the stuff specifically to do this but I don't ever recall seeing it at a truck stop just online only.
    nextgentrucker, tscottme and Oxbow Thank this.
  3. Oxbow
    Oxbow Road Train Member
    13,985
    146,145
    Nov 24, 2015
    You should be able to find air-line-antifreeze (alcohol based) in most truck stops and auto parts stores. I would not use anti-gell myself.
  4. Chicken wang
    24
    29
    Dec 11, 2023
    Cleveland, Ohio
    Thanks I looked for it before and never came across it. I will definitely order some online and pick it up when I go home.
    Rideandrepair and Oxbow Thank this.
  5. Animosus
    Animosus Heavy Load Member
    746
    3,016
    Dec 7, 2015
    SE Wyoming
    Isopropyl alcohol works in a pinch.
  6. Chicken wang
    24
    29
    Dec 11, 2023
    Cleveland, Ohio
    Thanks im going pick some up tomorrow. Luckily the truck stop I'm at has a Dollar General store across the street. The TA in Steele ,North Dakota. It's gonna get down to -4 tonight. I'll throw it in the side box and hope I never have to use it haha . If any rookies are reading this DON'T SET YOUR TRAILER BRAKES! to avoid them freezing up.
    Rideandrepair and Speedy356 Thank this.
  7. JC1971
    JC1971 Road Train Member
    2,688
    9,832
    Jul 29, 2013
    Southwestern U.S.
    You mean don't set the brakes.
  8. gentleroger
    gentleroger Road Train Member
    8,177
    22,456
    Jun 1, 2010
    The alcohol will erode the abs valves. 90% of the time it's not the lines that are frozen, it's the drums/pads. Release brakes, thump drum, rock, repeat until free. When it is the air lines, simply having them released and pumping the service breaks will clear the problem after a few minutes. To avoid the air freezing, drain your air tanks daily (a couple seconds is fine) and do the cdl brake test daily.
  9. Chicken wang
    24
    29
    Dec 11, 2023
    Cleveland, Ohio
    That's what I ment I will edit that. Thanks for letting me know.
    Rideandrepair Thanks this.
  10. Chicken wang
    24
    29
    Dec 11, 2023
    Cleveland, Ohio
    I agree the first thing I would try is
    I agree tapping on the brake drum with a hammer is probably the first thing to try.
    Rideandrepair and FullMetalJacket Thank this.
  11. tscottme
    tscottme Road Train Member
    I've very rarely used cheap isopropyl alcohol (rubbing alcohol) to free up the ice inside one of the air lines. Rubbing alcohol, post-pandemic, must be way cheaper than the stuff sold for the same purpose. I've been told to not use more than 1 cap-full of alcohol, MORE IS NOT BETTER.as It dries out any rubber or felt seals. If a little bit of it doesn't solve your problem in seconds, more will not fix your problem.
    When I used it, I set both brake valves in the truck. Disconnected 1 glad-hand at a time, and poured a cap-full of alcohol into each glad-hand and then reconnected both to the trailer and pushed in my brake valves. About a second later I heard a ker-chunk and my brakes were working.
    Numb, Rideandrepair and Speedy356 Thank this.
