Any 1 Help
Discussion in 'Volvo Forum' started by Blazeintrails, Dec 31, 2013.
  1. Blazeintrails
    Blazeintrails Bobtail Member
    4
    I have a 2000 770 VNL I have a problem with it feeling like it want's to wash the rear end around on me when I hit grooves in the Road. I have replaced just about everything I can. New complete Front springs, bushings, pins, new cab shocks, rear pucks and torsion bars. Just can't figure it out, Dynamite coming soon any 1 Help
  3. bad-luck
    bad-luck Road Train Member
    3,435
    6,326
    Nov 16, 2013
    Baltimore, Maryland
    King pins maybe. But please describe the problem in more detail
  4. gpsman
    gpsman Road Train Member
    1,581
    1,211
    Dec 10, 2013
    45212/59759
    That's a pretty vague description. Might be normal, might be you're feelings are wrong. Might be alignment, which I would have checked first before I started throwing parts at it. Might be your seat is loose, might be a drive axle is loose, might be a cracked or twisted frame. If you yank the same trailer all the time the issue may lie there.
  5. baha
    baha Road Train Member
    4,137
    2,837
    Jul 25, 2013
    ga
    CK. tie bolts on FT. axel.
  6. OttMan
    OttMan Medium Load Member
    321
    207
    Nov 2, 2013
    Georgia
  7. Blazeintrails
    4
    I have changed the King Pins it has a feeling like low tire's but they are new both drive and steer. Cab has good flex up and down and right to left, 5 years ago or so I changed the steering sector, the control arm to steering wheel. It just doesn't want to hold a straight line and I have had a 3 wheel alignment just done.
  8. Blazeintrails
    4
    Sad thing about it is trailer or not does it all the time had everything checked top to bottom can't find any issues with loose drivetrain, cab, or suspension.
  9. BulletProof
    BulletProof Medium Load Member
    503
    322
    Feb 17, 2013
    Alabama
    Do you have new or near new drives? I've got around 20,000 on my new set of drives and it still walks real bad in the grooves or feels like the rear end wants to wash out in a turn. The tread hasn't worn down enough yet and knobs on the tires roll over.
  10. d281833
    d281833 Heavy Load Member
    881
    919
    May 15, 2012
    Air ride leveller?
  11. gpsman
    1,581
    1,211
    Dec 10, 2013
    45212/59759
    "Tread squirm".
