ANY APU GURUS HERE
Discussion in 'Ask An Owner Operator' started by thecubantrucker, Jul 10, 2021.
  1. thecubantrucker
    thecubantrucker Light Load Member
    149
    92
    Jun 2, 2019
    Good morning fellow truckers so I'm having an issue with my thermoking tripac apu hopefully any of you guys had same issue and can enlighten me. Apu will start runs fine ac compressor kicks on and blowing cold air after 5 or 10 minutes it will shut off my controller will reboot pretty much checked fuses checked maxi fuse all grounds checked voltage on alternator checked belts all good no codes I 2 occasions at abput 2am apu turn of with an alt code but never done it again after it started doing this. could it be a bad freon charge or air on the system any input would be appreciated
    truckdriver31 Thanks this.
  3. Arctic_fox
    4,509
    25,466
    Sep 16, 2016
    First if you have a laptop download thermo kings software. Its free and is the same software they use in house. Products look under features. This will help pin down exactly whats going on. If no codes check how long they have the "target run time" set for. When i got my 579 it was set to 2 hours and i was able to reset it to 12.
    Next top off the coolant if its a closed loop. Could be its overheating due to low coolant. Dont let it looking full fool you. Ive had mine look half full then take 2 quarts of coolant and never throw a code. Also check your oil. Make sure its full or near so. Low oil can cause it to shut down and wont always throw an error.
  4. thecubantrucker
    149
    92
    Jun 2, 2019
    so it's got a fresh pm new filters new oil etc the coolant got plenty of it it is directly connected to the truck coolant all I do is open the valves and for the program does it connect to the apu or is it just a trouble shooting program thank you
  5. Arctic_fox
    4,509
    25,466
    Sep 16, 2016
    Direct connection, same tool the dealer uses.
  6. thecubantrucker
    149
    92
    Jun 2, 2019
    got you gonna check it out soon as I come back home thank you for that input
  7. scoobertdoo
    scoobertdoo Road Train Member
    1,512
    2,603
    Nov 11, 2020
    I have a truck that shuts down at 3:35 pm. Can you help me?
    You might want to tell us WHAT Apu you have.
  8. thecubantrucker
    149
    92
    Jun 2, 2019
  9. scoobertdoo
    1,512
    2,603
    Nov 11, 2020
    Plug it in, read the codes, look at sensors
  10. thecubantrucker
    149
    92
    Jun 2, 2019
    question for you on the controller I'm not getting any codes does it stay stored on the ecm themselves
  11. scoobertdoo
    1,512
    2,603
    Nov 11, 2020
    Like a semi, reefer, or even a car, they stay stored.
