Any good handheld CBs?
Discussion in 'CB Radio Forum' started by Caynnor, Aug 5, 2014.
  1. Caynnor
    Caynnor Light Load Member
    73
    41
    Sep 29, 2013
    Covina, Ca
    I drive local and my boss doesn't want CBs installed in the trucks so I was wondering if there were a good handheld I can use in the truck?
  3. greenrover
    greenrover Bobtail Member
    10
    4
    Aug 4, 2014
    L.B. Thanks this.
  4. Farmboy319
    Farmboy319 Bobtail Member
    9
    Southern California
    The midland 75-822 is a good radio but I've got a cobra 38 wxt and it performs great.
  5. Caynnor
    73
    41
    Sep 29, 2013
    Covina, Ca
    Thanks guys, it is a pain but my boss has a thing about distractions in the truck and I miss having a CB.
  6. Hardlyevr
    Hardlyevr Road Train Member
    3,270
    2,540
    Jul 30, 2009
    Mapleton Depot,PA
    get a magmount antenna and a BNC converter cable end, otherwise reception and your transmissions from inside the cab will be terrible. Depending on the truck, you may have background noise issues with a handheld too.
  7. L.B.
    L.B. Third Generation Truck Driver
    2,654
    1,055
    Jul 23, 2007
    Middle GA
    The midland doesn't need a converter, it comes with a power adapter that accepts a standard antenna connector. The bnc on the top is for the handheld antenna used with the battery box on the bottom
  8. L.B.
    2,654
    1,055
    Jul 23, 2007
    Middle GA
    Also, trying to use the handheld antenna inside a cab is useless, a good magnet mount is essential.
  9. L.B.
    2,654
    1,055
    Jul 23, 2007
    Middle GA
    The midland also comes with two battery boxes. One for use with standard AAs. One for use with rechargeable batteries.
  10. greenrover
    10
    4
    Aug 4, 2014
    That's right. The coax pigtail coming out the bottom of the midland is a SO-239 connector which fits the PL-259 antenna coax side. External antenna is a must like L.B. said.
