Any ideas on this radio issue?
Discussion in 'CB Radio Forum' started by 88 Alpha, Jun 26, 2014.
  1. 88 Alpha
    88 Alpha Trucker Forum STAFF Staff Member
    5,595
    18,185
    May 12, 2012
    SouthEast Alabama
    I have a Cobra 148 GTL and have had it for years in various and sundry trucks. In the past couple of months, it has developed a "pulse" when people talk. To better describe the issue, when I have the squelch turned where I can hear some noise, static, etc, when someone talks, you can see the meter go back and forth, left to right and it will continue doing so until the person quits talking. Occasionally, the radio will do this when there is just static noise. It would be easy to say someone nearby is keying and unkeying their microphone, but the problem happens all of the time. Additionally, I have a distance problem. If I cannot see another truck, I cannot hear another truck, even with the squelch all the way to the left and the RF gain all the way to the right.
    The antenna set-up is all factory on an 2012 International Prostar. I have a decent antenna set-up at home, when I ever get there, that will be taking the place of the factory stuff. It is Wilson Super Mini 8 silver coax, 4 ft Firestick II antenna and a big gaudy-looking K-40 6-allenscrew antenna mount. I prefer the Firestick brand due to being Made-in-the-USA.
    The SWRs on the unreliable radio meter shows 1.30:1.75 from channels 1 thru 40 and it is consistent every time I check them.
    Do you think the new antenna set-up will alleviate the pulsing and distance problems or do you think it's time to let a shop check out the radio?
  3. Picklechips
    Picklechips Light Load Member
    103
    34
    Feb 23, 2014
    It is weird to have both TX and RX problems. My guess would be antenna. To be honest those factory set ups are not very good. You are better off changing it out anyway.
    *edit
    Replace the coax also.
    88 Alpha Thanks this.
  4. 88 Alpha
    5,595
    18,185
    May 12, 2012
    SouthEast Alabama
    Thanks for your input. And yes, everything from the coax to the antenna tip will get replaced.
    I also understand inverters left on will make a difference from time to time. I have a small inverter constantly on, keeping power to my laptop but turning the inverter off makes no difference in TX or RX.
    If I had a back-up radio, that would help narrow down where the problem is, but I hardly ever use my primary radio, so a back-up would get zero use (except for trouble shooting).
    Thanks again.
  5. jessejamesdallas
    1,416
    855
    Oct 3, 2008
    Republic of Texas
    The pulsating noise sounds like your picking up some electrical interference from something inside the truck turned-on...Do you have something like a cell phone charger plugged in to a cigarette lighter outlet? I have had chargers make pulsating type noises on the radio before...Could also be the laptop or the power inverter, but the noise should go away when the inverter is turned off.
    Does the noise go away when the motor is turned off?
    As for as not being able to hear or talk to people, unless their right in front of you, sounds like a antenna or coax problem...Might check your connectors on the coax...Or try disconnecting the coax from the radio and antenna, and use a temporary coax to connect the radio to the antenna, and see if the noise go's away and see if you can hear and talk better...
  6. 88 Alpha
    5,595
    18,185
    May 12, 2012
    SouthEast Alabama
    The pulsating is not as bad when the truck is turned off but I hadn't thought about the cell phone chargers. I will try that and see if unplugging them make a difference. That may very well be part of the problem (3 chargers).
  7. 88 Alpha
    5,595
    18,185
    May 12, 2012
    SouthEast Alabama
    Here is a little update for anyone interested.
    I finally went home and got my new antenna, coax, and mounting bracket. I needed a wrench that was in my truck, so I took my tool bag from the truck to my POV.....and promptly forgot about it when I left, so now I have a complete new set-up in the truck and no wrenches to install them. I will eventually get everything on the same page.
    On a side note, I stopped at a recommended CB shop late last week. I described the problems and the gentleman checked out the radio. He found no issues with it (I know, big surprise, but at least that is one area that can be eliminated from the troubleshooting). He asked me what antenna I was using. I told him factory-installed. He mentioned the pulsing problem could be due to the electronics in the truck (inverter/laptop, as has already been mentioned in this thread) OR he said it could be the antenna has a broken wire (not necessarily the coax, but on the antenna itself) and that could be the reason for the pulsating...going down the road, with the movement of the antenna in the wind, if it has a broken wire, the wire is making contact, then loosing contact, then making contact, etc.
    While I don't know about the certainty of that, I like the theory. It makes sense to me. That would very well explain why there is much less pulsating when the truck is stopped and account for why I can only hear folks or talk to them if I can see them. It might end up my antenna is the reason for both issues.
    Stay tuned.....
  8. MsJamie
    MsJamie Road Train Member
    As a simple test, try screwing your Firestik into the factory CB mount. It's very possible that one of your whips does have an intermittent connection, probably in the base where the wire solders to the threaded metal "cap". It could be either one of the antennas.
  9. Powder Joints
    8,021
    8,482
    Sep 25, 2007
    Rosamond, SoCal
    Back in the day, I ran a 102 whip on a 4 inch spring, there is a braid inside the spring, if this broke it would cause exactly what your describing. hange out the antenna.
  10. 88 Alpha
    5,595
    18,185
    May 12, 2012
    SouthEast Alabama
    Just to update, I finally got home, retrieved my tool bag and when I stopped the 1st time after leaving home, I removed the driver's side factory antenna and replaced it with the 5' Firestick II. Had my CB on all day long today, as well as my 400 watt inverter, laptop, refrigerator, and 3 cell phones charging.
    It appears the tech at Chucks CB Shop in Holladay, TN was correct. Evidently there was a broken wire inside the antenna. The new antenna made a huge difference. Even though I have a new bracket and coax, to maximize time, as well as continue troubleshooting, I only replaced the antenna. With all the electronics on, there was no pulsing and I could send and receive for miles. It makes me very curious and anxious to see what installing the new coax and real bracket (as opposed to an "in-the-mirror" bracket) will do.
    Thank you to all who have offered advice. As it turns out, some of it actually helped solve the problem but I am grateful for all of the suggestions.
