Any Issue Reusing Main/Rod Bolts?
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Hilltop Hustler, Aug 12, 2025.
  1. Hilltop Hustler
    Hilltop Hustler Light Load Member
    79
    52
    Apr 29, 2023
    West Virginia, USA
    So I'm going to buy a new 855 block and recycle parts. At the moment (haven't pulled heads yet only got a peep through the bottom) everything but the #2head, #2rod, head gasket, and of course rod and main bearings are getting recycled(engine block cracked on the number two piston). I am trying to watch my budget on this fix and was curious if I could reuse rod and main bolts.
    Im much more cautious using head bolts since it seems the failure came from the piston head itself. 20250804_201504.jpg
    BoxCarKidd Thanks this.
  3. Hilltop Hustler
    79
    52
    Apr 29, 2023
    West Virginia, USA
    Excuse me not #2 head, #2 piston head
  4. BoxCarKidd
    BoxCarKidd Road Train Member
    4,548
    6,641
    Aug 26, 2014
    I would replace the rod bolts and reuse the mains if they look OK. Maybe line them up side by side. If any are longer replace them also. I could go on and on why but that is what I would do.
    Rideandrepair and Hilltop Hustler Thank this.
  5. 201
    201 Road Train Member
    12,779
    26,297
    Apr 16, 2014
    high plains colorado
    I heard any bolt that gets a torque, stretches a little bit, and new ones should always be used.
  6. Ridgeline
    22,720
    123,337
    Rod bearings - OK to reuse with the same crank.
    Mains - replace
    Headbolts - replace
