Any pipe haulers?
Discussion in 'Flatbed Trucking Forum' started by orcen, Jan 18, 2014.
  1. orcen
    orcen Heavy Load Member
    844
    473
    Jun 30, 2013
    Brisbane, QLD Australia
    I usually haul big pipe and only 3-4 pieces, however this week I'm hauling small 5"x50' 63 piece loads, check out the pic below,
    My question is; is it secured correctly? Or should I have put the straps on the bottom layer at the very end and did it the other way?
    Any input would be great, thanks!
  3. baha
    baha Road Train Member
    4,137
    2,837
    Jul 25, 2013
    ga
    Is that 7 straps over the top?
  4. orcen
    844
    473
    Jun 30, 2013
    No 9 I think... First load like this so I wanted to make sure it was locked down...
    4 on bottom, 4 on middle and 9 on top
    baha Thanks this.
  5. kylefitzy
    kylefitzy Road Train Member
    4,753
    19,806
    Aug 12, 2007
    Kansas city,Mo
    I would put a belly wrap at each end with a chain.
  6. baha
    4,137
    2,837
    Jul 25, 2013
    ga
    Looks good,2 belly straps never hurt, they help stop center pipes from slipping out from the middle of load on hard breaking. The 1st 2 straps over top must be close to 8ft. from ft. of load.some co. say 10ft.?
  7. orcen
    844
    473
    Jun 30, 2013
    they aren't loose, there are 21 bundles, 7 on each layer... chains not required
  8. Lalito1234
    Lalito1234 Light Load Member
    108
    7
    Oct 2, 2013
    chicago il
    i haul pipes every now and den from calumet city,IL and i always Choke them from the front wit like three straps, i tink its called belly wrap tho lol
  9. RERM
    RERM Road Train Member
    1,683
    1,125
    Dec 13, 2012
    Chicago, IL
    Gut straps are only for the second layer (if total height is gonna be over 5' or when there will be more layers above)....You didn't have to gut strap the first layer....Also, the gut straps are only used one at each end of each bundle if multiple bundles (not your case here)....in our company we use belly wraps for steel bars and such...not pipe....
    Each securement should be no more than 8' apart and, of course theres no maximum securements (as many as you want).
    I just carried this load a week ago and had to call safety to check on my securements...so that's why I'm being so technical I gues!!!
    good luck!!!
    orcen Thanks this.
  10. jpracer1
    jpracer1 Medium Load Member
    439
    198
    Nov 26, 2009
    a little overkill on the strapping,i would have went 2 on the 1st layer,2 on the 2nd and probably 7 on the top layer,banded and bundled it wont go anywhere,crank down on those straps and good to go
  11. snowwy
    snowwy Road Train Member
    20,612
    13,333
    Jul 6, 2009
    it's a dot requirement. 2 straps within the first 10 feet. and 10 feet max there after.
    i would have done 3 straps belly wrapped. since you don't have pipe stakes.
    i watched a guy haul 4 layers of 18 inch round pipe. he wrapped each layer with a chain and binder before the loader loaded on the deck. i'm wondering if that would be a comparible securement to actually having pipe stakes. when your hauling the bigger stuff.
