ANY THOUGHTS
Discussion in 'Ask An Owner Operator' started by Coma1, Apr 6, 2023.
  1. Coma1
    Coma1 Bobtail Member
    15
    19
    Oct 31, 2019
    My 2020 KENWORTH W990 GVWR is 53200 ,GAWR FRONT 13200
    GAWR 1ST INTERMEDIATE 20000.
    Please can someone tell me what’s my max weight I can haul
  3. AModelCat
    163,884
    Depends on how many axles you have behind you.
    Also depends on what jurisdiction you're in.
  4. Rideandrepair
    17,524
    56,769
    Aug 8, 2015
    Just what it says. 13209 steer, 20000 per drive axle. So 40000 total for drive axle group. Standard law is 80000 gross, pulling a dual axle trailer Same 34000 limit applies. Assuming the Trailer also has 2 20000 axles, and Providing you have overweight permits, you could theoretically be up to 93200 gross Legally. Add more axles on the Trailer, and gross goes up accordingly. The rules are 34000 for an axle group, and 20000 for a single axle. Spread a low Trailers fall under the 20000 rule. So as long as your at 80000 gross, with a spread axle you can have 40000 on the Trailers axles. Same 20000 single axle rule applies for the steer, or a single drive axle Tractor, or single axle Trailer, You can go up to 20000. Not a problem on the Truck or Trailer. Only limited on the steer by the actual Axle rating, or tire rating.
    Another Canadian driver and Coma1 Thank this.
  5. abyliks
    abyliks Road Train Member
    4,077
    9,588
    May 2, 2010
    ludlow MA
    40k on the rears, depending on which set of rears you have 140-170 total gross
  6. Coma1
    15
    19
    Oct 31, 2019
    Thanks
