Anybody use a predator 2000 + small AC unit?
Discussion in 'Ask An Owner Operator' started by speedstickman, May 8, 2024.
  1. speedstickman
    speedstickman Light Load Member
    66
    20
    Jul 10, 2012
    Looking to get a predator 2000 and a small portable AC unit (under 5000 btu)
    Does anyone use this set up? Will this even work? if so, how long would this run for? any recommendations to set this up? I was originally planning on getting the predator 3500, but it will be too big/heavy to move around since I was planning on storing the generator in the truck while not in use (chained to the truck outside when in use)
    Thank you
    77fib77 Thanks this.
  3. TheLoadOut
    TheLoadOut Road Train Member
    2,430
    11,645
    Nov 6, 2019
    My Pulsar generator from Ace hardware has run my a/c for 10 hours on Eco Mode many times. You should have no problem.
  4. speedstickman
    66
    20
    Jul 10, 2012
    What kind of AC are you using ? and which pulsar?
    I'm planning on using this AC:
    Robot or human?
    Do you think the predator 2000 could run this?
    Thanks
  5. TheLoadOut
    2,430
    11,645
    Nov 6, 2019
    GE window unit a/c, can't remember the BTU's but have never had an issue. Friend of mine runs a similar set up to what you want to do, he's had no issues either other than the a/c unit being bulky in the cab.
  6. speedstickman
    66
    20
    Jul 10, 2012
    That pulsar runs a small ac unit for 10 hours? wow that's crazy! I think im gonna go this route... thank you! Also... what do you mean by eco mode? do i need an AC that has it ?
  7. TheLoadOut
    2,430
    11,645
    Nov 6, 2019
    The Pulsar has an Eco Mode setting, just a switch on the control panel. If for some reason it won't run your set up on the Eco Mode you'd just run it normal, or not in Eco Mode.
    Soltaker Thanks this.
  8. speedstickman
    66
    20
    Jul 10, 2012
  9. TheLoadOut
    2,430
    11,645
    Nov 6, 2019
    Yes, I think it would work just fine.
  10. abyliks
    abyliks Road Train Member
    4,146
    9,787
    May 2, 2010
    ludlow MA
    Yes but your going to need a 8k btu minimum and I have a 10k, sleepers have horrible insulation, tucked the cord into the frame and ran it to the bunk, next to my investor so all I have to is plug in the gen by the landing gear
    dwells40 Thanks this.
  11. staceydude
    staceydude Road Train Member
    1,151
    5,041
    Apr 3, 2020
    I used a 5k window unit with a 2200 watt Yamaha. It worked great even in in Arizona and Texas and Florida. A bit redneck but window units are much better than the stand up type. One thing though to make it freeze you out is take a dryer duct or some type of hose and gorrilla tape it to the outlet section so you can direct the air straight to sleeper and point itwhere you want it. I often had to direct it away from me after awhile even on hot days.
    This was the cheapest Toshiba window unit at Home Depot. Just a knob or two. Nothing fancy.
