Anyone else have issues with motive ELD and the electronics?
Discussion in 'ELD Forum | Questions, Answers and Reviews' started by Ragbonetransport, Sep 16, 2025.
  1. Ragbonetransport
    Ragbonetransport Bobtail Member
    15
    20
    Jan 25, 2020
    Using motive ELD in my Volvo vnr640 D13 engine. Worked fine for a few months, out of nowhere my truck starts tossing up codes. The codes go active momentarily then inactive (like there’s a short in my electrical somewhere.) Took the truck to Volvo, they diagnosed my problem and told me it was my ELD malfunctioning. I left it unplugged, ran paper logs instead. Truck worked fine. Purchased a new motive, plugged it in to my truck, and my electrical issues came right back. 2 different motive units, same problem. Anyone else experience this?
  3. sirjeff
    sirjeff Medium Load Member
    I had problems in my volvos with motive. It never worked properly at all with the cord that it came with (that piggyback off the obd port) Where is your gateway tied in? Obd port or up top in the dash fuse box somewhere? Theres a data link wire in behind there that worked much better as a tie in spot... maybe a different cable would take care of this
    Ragbonetransport Thanks this.
  4. Ragbonetransport
    15
    20
    Jan 25, 2020
    Mine ties into the datalink (green and yellow wire) up top at the fuse box. Terminating resistor is good. One of the momentary messages that pops up on the dash is that the j1939 datalink is shorted. But when I shut the truck off and use an ohmmeter, everything checks out. No shorts and 60 ohms on pins 3 and 11 at the port. There’s only 2 terminating resistors, one is at the fuse box the other is inside the ECM.
