Anyone replaced a WS window controller?
Discussion in 'Western Star Forum' started by 04 LowMax, Dec 6, 2014.
  1. 04 LowMax
    04 LowMax Medium Load Member
    440
    250
    Feb 3, 2013
    Alberta
    My drivers side window has been going up and down at a snails pace for a long time, and now is on it's last legs. How nasty of a job is it to replace? I really don't want to go back to the dealership at $165 per hour unless it's going to be something that I can't or shouldn't tackle.
  3. baha
    baha Road Train Member
    4,137
    2,837
    Jul 25, 2013
    ga
    TRY spraying silcone down window felts on each side, Nothing a set of torx head tools cant fix CK. where the wires go threw FT.of door an flex that is where wires wear into bear copper and short out,if you slam door an it starts working better motor is going bad?
    04 LowMax Thanks this.
  4. Cetane+
    Cetane+ Road Train Member
    1,304
    882
    Sep 29, 2013
    Albany, NY
    If its the same as my 01 it will take less than an hour. I took mine out to fix a knock in the door.
  5. billm89
    billm89 Bobtail Member
    39
    19
    Jul 20, 2011
    Mass.
    Not bad to do at all. Half the time will be spent removing the trim and door panel. If your switch is really old,it might be a good time to replace it also. One of mine had slow and intermittent operation which was cured with a new switch.
