Anyone Running An FLD?
Discussion in 'Flatbed Trucking Forum' started by JimmyWells, Sep 4, 2016.
  1. JimmyWells
    JimmyWells Road Train Member
    1,000
    1,078
    Apr 7, 2016
    I need to know if I can still run a headache rack on a mid 90's FLD that has dual exhaust running along the sleeper. Anyone running one or one similar?
  3. johndeere4020
    8,522
    119,295
    Jan 1, 2010
    Why couldn't ya?
  4. passingthru69
    Yea as long as you got swing room when you turn
    I have a Fld but my stack is on the side not rear
    JimmyWells Thanks this.
  5. passingthru69
    Hook to your trl. Then make a hard left or right and then get out and measure your space from trl to back of sleeper
  6. MACK E-6
    50,089
    238,984
    It won't work with an RGN unless you have fenders on it.
    But if your hooked to any 102" wide trailer, all you have to do is articulate to 45 degrees. That puts the corner of the trailer as far forward as it will get.
  7. JimmyWells
    1,000
    1,078
    Apr 7, 2016
    You mean if I DON'T have fenders on it, it will fit?
  8. MACK E-6
    50,089
    238,984
    Well, in a scenario where the front corner of a regular trailer WOULD hit your rack, an RGN won't because a regular gooseneck is more narrow.
    JimmyWells and johndeere4020 Thank this.
  9. Hurst
    Hurst Registered Member
    6,618
    12,266
    Aug 24, 2011
    Tampa, Fl
    Ideally you would buy a headache rack designed to fit the truck. Not the other way around.
    I have a Columbia with dual exhaust out the back. It has a condo sleeper with the extensions/fenders. I pull a 53x102 step. Plenty of room.
    Dont try to over think it. Measure the space,.. and buy what you think will work.
    Hurst
    peterbilt_2005 and JimmyWells Thank this.
  10. MACK E-6
    50,089
    238,984
    How's the kingpin setback on your step?
    Something else to keep in mind as well.
  11. Hurst
    6,618
    12,266
    Aug 24, 2011
    Tampa, Fl
    That for me or the OP?
    Mine has 18inch set back with the 5th wheel set all the way rearward. That and I have a slightly longer than average wheel base Columbia. I can overhang 3 - 4 ft off the front with out issues,.. even with the headache rack in place.
    Hurst
    Lepton1 and JimmyWells Thank this.
