APRS and trucking
Discussion in 'CB Radio Forum' started by L.B., Dec 14, 2014.
  1. L.B.
    L.B. Third Generation Truck Driver
    2,654
    1,055
    Jul 23, 2007
    Middle GA
    Wondering who uses APRS while in a truck. I've heard of guys using it to identify others to call up while driving and being able to broadcast their freq for others to call them on. Monitoring www.aprs.fi in my area doesn't pull up many mobile tracks. Aprs radios are few and expensive. Aprs trackers can broadcast but not receive. I've looked at using an old android phone and the aprsdroid app hooked to a HT but I haven't been able to get it to process incoming packets. There are internet based apps that will send and receive but I would not want to tie up my phone on apps like iAPRS.
    Thoughts?
    Does anyone use this mobile?
    Is it worth my time to bother with it?
  3. MsJamie
    MsJamie Road Train Member
    I run APRSdroid on my phone when I'm OTR. The data usage is minimal, and it runs in the background. Friends and family know how to find me on aprs.fi, which can make for some interesting conversations.
    I do want to set up an RF based APRS tracker. I just need an APRS-friendly ROM for my TNC.
  4. L.B.
    2,654
    1,055
    Jul 23, 2007
    Middle GA
    I wish they had a version for the iPhone. I am hooking the old droid phone I have to a uv-5r for an rf aprs. It transmits and I've been able to get to hit a digitpeater but I need to rewire a connection to get to receive packets since the pin out for the speaker is different than a normal headphone jack. This works without a tnc on aprsdroid. Just need to adjust the vox setting on the ht. With a mag mount antenna I should get a better range. That'll be my next test once I have a cable rewired. A standard audio cable plugged from the phone to the mic input on the ht works fine for transmitting. Receiving rf signals you should be able to use the hub view to see local aprs transmitter info like you would see on a kenwood receiver.
  5. L.B.
    2,654
    1,055
    Jul 23, 2007
    Middle GA
    IAPRS for my iPhone will transmit my location once I have an account created for it but it won't run in the background. It only connects when it open and displayed.
  6. MsJamie
    That is the result of a deliberate design decision in iOS; no multitasking. Apple says that you only need to do one thing at a time; therefore, you can't do more than one thing at a time. Even if that other thing needs no human interaction whatsoever.
    Just one of the ever growing list of reasons why I gave away my iPhone and went to Android.
  7. L.B.
    2,654
    1,055
    Jul 23, 2007
    Middle GA
    I think that is true in older versions of iOS but I have gps apps that will run in the background and give audio alerts when not up on the screen. Some apps give the option to run in the background. Perhaps the iAPRS app needs to be updated.
  8. L.B.
    2,654
    1,055
    Jul 23, 2007
    Middle GA
    Waze for example will give audio alerts when I pull up another app. It may only work when the app is in the second position. In other words I try to only open one other app over top of the app I want to keep running. I do have one gps app that will quit (gives an alert that it's quitting) when another app is opened over it just like iAPRS does.
  9. L.B.
    2,654
    1,055
    Jul 23, 2007
    Middle GA
    Got my pass code for aprs-is in email so I will try running that today to see how well it updates. Tomorrow I will take my radio setup and compare the two. I run the same route most days.
  10. L.B.
    2,654
    1,055
    Jul 23, 2007
    Middle GA
    Found out something interesting about iAPRS and iOS. IAPRS will actually run in the background and update the aprs-is server. Apparently it doesn't receive in the background, which is why is shows "reconnecting" when you pull the app back up.
    I got the aprsdroid app to hit digipeaters using a mag mount antenna connected to my uv-5r. I still need to rewire a cable to get the app to receive packets over the radio. The only reason I want this is to see incoming local info similar to the way one of the kenwood radios would display it. If I can get it to work I was looking at a cheap android tablet for the bigger display.
  11. OFTOTR
    OFTOTR Medium Load Member
    653
    678
    Jul 19, 2011
    Toccoa GA
    If you have a smartphone with a gps, aprsdroid will work by itself, no radio needed.
    I flip mine on off and on, but use a separate yaesu vx8g most of the time.
    I don't have any need to see who is around me, but my friends and family can see where I am, and preferably if I am moving or not.
