APU and AC trouble
Discussion in 'Trucks [ Eighteen Wheelers ]' started by TowHaul, Jul 19, 2025.
  1. TowHaul
    TowHaul Medium Load Member
    416
    79
    Mar 7, 2016
    I have a pro-heat 1st gen? apu. Since I bought the truck (8 years ago) I have been unable to fix the ac which does not work. (everything else works including heat). I tore apart the bunk yesterday and evacuated and recharged the AC. The low side PSI is reading a negative vacuume with the compressor running, high side is around 100 psi (80F outside). The evaporator bulbs soldered onto and going into the evaporator core are both frosted. Putting a heat gun on them made no changes. Everything I am reading is that the TVX valve may be stuck, but I am absolutely unable to find anything that remotely looks like a tvx valve, I did find the filter drier which has the capillary copper tubes, coming from the sensing bulbs and going into it. I am not sure what to do next, i've tried tapping on everything, heating up parts, but no difference in colder air temp. Everything including the evaporator fan and the condesor(?) fan outside of the truck appears to be working properly... I hate quitting on DIY projects but I am totally stumped. I dont want to chop open the system and replace the drier when the problem is likely something simple or totally unrelated. *ANY help or advice would be appreciated.
  3. TowHaul
    416
    79
    Mar 7, 2016
    also reading that despite the compressor starting/running that a bad or weak capacitor could cause a negative vaccum
  4. BoxCarKidd
    BoxCarKidd Road Train Member
    4,555
    6,643
    Aug 26, 2014
    Hi and low side pressures sound low. Are you sure it has enough freon.
  5. TowHaul
    416
    79
    Mar 7, 2016
    put in 2 cans, low side should never be in a vacuum. Also frosting leading out of the evaporator core is likely a sign of either a obstruction (Drier/Filter? Capillary Tubes? TVX?) or maybe weak capacitor.
  6. Deezl Smoke
    Deezl Smoke Medium Load Member
    542
    356
    Feb 12, 2011
    Hillsboro Oregon
    If someone put refrigerant in with a sealant, there is a good chance you have a plugged orifice.
    Your compressor is just that, a compressor. So if you have a restriction on the inlet, the ability to raise pressure on the outlet is reduced.
    What are the gauge readings static? Both sides should equalize.
  7. JB7
    JB7 Road Train Member
    1,040
    1,835
    Dec 13, 2022
    Laurel, MD
    Follow the lines. There are 2 lines connected to the compressor. One is the high pressure discharge which goes to the condenser. The other is the suction side which comes from the evaporator. Follow the outlet line from the compressor to the condenser then the outlet line from the condensor to the evaporator. An expansion valve or orifice tube will be in the line coming from the condensor but before or right at the evaporator.
  8. BoxCarKidd
    4,555
    6,643
    Aug 26, 2014
    It is unusual to me for any mobile air units to run under 175 - 200 Lbs on the high side. Usually higher. The low side usually runs 25 - 40 Lbs. Claas 980 chopper blows all that away. No one told those Germans you needed high pressure to be cool.
    Sounds to me like you are low on the high side and low on the low side. I would start with adding more freon.
  9. TowHaul
    416
    79
    Mar 7, 2016
    Both high and low sides do equalize when the compressor is off. Was around 90 psi I think.
  10. TowHaul
    416
    79
    Mar 7, 2016
    No expansion valve was found anywhere. I know what they look like and I've follow all the lines. The frost is on the copper bulbs going into the evaporator. I've tried looking for parts diagrams to find the expansion valve, but no luck. Seriously traced all the lines. Read somewhere that the capillary lines some act as metering devices rather than having an expansion valve. Bought the truck with this ac problem and just trying to fix it now 8 years later... No clue in prior history
    Deezl Smoke Thanks this.
  11. TowHaul
    416
    79
    Mar 7, 2016
    The frosting the copper lines going into the evaporator after adding a second can should indicate a problem should it not? After two cans shouldn't I have a low but positive reading in the low side, not a negative vacuum?
