APU coolant system plumbing question.
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by calvinbabb, Sep 17, 2022.
  1. calvinbabb
    calvinbabb Light Load Member
    66
    41
    Apr 28, 2016
    Trenton, Fl.
    I currently have a carrier comfort Pro that has its own radiator system on it. I want to plumb it into the truck coolant so that during the winter the APU will help keep the engine warm for cold day start up. I’m thinking, in theory, I only need to cut into one of the heater lines going to the bunk basically running the coolant from the radiator towards the bank diverting it to the APU, and then back up to where I cut in to the Same line headed towards the heater coil. Basically what I’m asking is, I should only have to cut into one of the heater lines going to the bunk, correct?
  3. Antinomian
    Antinomian Road Train Member
    2,175
    3,448
    Feb 17, 2013
    Mine (09 Cascadia) was plumbed that way, but it was plumbed in parallel, not in series. I think it's best not to have the restriction of having to push APU coolant through the bunk heater core. Make sure you add shut off valves on both the feed and return sides. I used to get leaks when I first bought the truck. Connections had to be really really tight there.
    If you're truck is an older Cascadia you will have the annoyance of having to deal with two different size lines to the bunk heater core. One was 3/4 and one was 3/8. But you'll want 3/4 on both sides going to the APU. This is what I used for that: Four Seasons 84757 Plastic T-Type Hose Splicer. Be careful, they break.
  4. GYPSY65
    GYPSY65 Road Train Member
    1,957
    5,265
    Nov 16, 2012
    SW FLA
    If your truck has an electric motor heater you should also be able to plug it in
    A friend of mine did that. Just ran an extension cord to the external plug in
  5. calvinbabb
    66
    41
    Apr 28, 2016
    Trenton, Fl.
    It’s on a 18’ t680 but should be similar
  6. calvinbabb
    66
    41
    Apr 28, 2016
    Trenton, Fl.
    I bought the truck second hand and when I got to checking there is no block heater on this truck. This is why I want a plumber APU into it. I tend to run up into Montana and stuff quite a bit in the winter, so that little extra will help at start up. I know I can add a block heater, but figured might as well just plummet APU into it and be done with it.
    GYPSY65 Thanks this.
  7. Dave_in_AZ
    424,953
    My tripac is plumbed into the radiator. As was mentioned shut off / isolation valves for supply and return.
    It has a Wabesto though. It definitely saves the day in freezing conditions.
