APU fan not working
Discussion in 'Ask An Owner Operator' started by Phoenix Heavy Haul, Jun 27, 2022.
  1. Phoenix Heavy Haul
    Phoenix Heavy Haul Medium Load Member
    469
    1,398
    Feb 8, 2022
    Raleigh NC
    APU busted top radiator hose and dumped all my coolant in middle of ATL a week ago. Nevertheless ordered a new hose put it in and now it’s getting hot and shutting down.
    Turns out my APU cooling fan isn’t coming on. I unplugged it and straight wired it and fan works fine and unit ran as normal no shutoff etc.
    I haven’t checked fuse yet but I will in the morning. If that’s not it figured it be the temp sending unit for fan. It appears to be right below the thermostat on back of engine. Any suggestions or clarification as to where the temp sending unit is.
    It’s a Thermoking Evolution
    Vampire Thanks this.
  3. shatteredsquare
    shatteredsquare Road Train Member
    1,407
    1,841
    May 23, 2014
    middle dirt
    there's a fuse on control board that says PCF "primary cooling fan", the fan can easily pull more than the factory fuse rating on start up, (same for the *condenser* fan, the outside one), I've had a 20 amp fuse in place for PCF for ~3 years and it's been fine since then. i think the actual fan just finally died though cause PCF quit coming on and fuses are all still good. 15k hours is a decent lifespan, half of that was with zero protection from salt/sand/dust/snow/water without the cover. it would run fine up to about 90 degrees ambient before it would shut down for coolant temp, if you run it with the cover open the PCF isn't really necessary. but i think it baked the alternator cause now running the tripac takes more juice than it creates until the truck low voltage trips, time to throw some $$$$$$ at this beesh
    Vampire and Phoenix Heavy Haul Thank this.
  4. shatteredsquare
    1,407
    1,841
    May 23, 2014
    middle dirt
    MOBee and Phoenix Heavy Haul Thank this.
  5. Phoenix Heavy Haul
    469
    1,398
    Feb 8, 2022
    Raleigh NC
    Thanks I checked all fuses this morning well ones that said anything about fan at least. I got 9100 hrs on it and it’s starting to need a lot TLC. I wired up a fused cigarette lighter plug for fan for these next few nights and it seems to be holding. Ima order the fan sensor and see what happens
  6. Phoenix Heavy Haul
    469
    1,398
    Feb 8, 2022
    Raleigh NC
    Perfect thanks for the picture. I was pretty sure that was it but figured it couldn’t hurt to ask someone on here!
  7. Stringb8n
    Stringb8n Road Train Member
    1,705
    2,232
    Sep 27, 2015
    I had this issue today. In Phoenix never had this happen before. Ran fine I thought the ac compressor stayed on too long or maybe lost some coolant when ENG showed on my controller. I have the old style tripac. It tripped the reset breaker or switch and I reset it and started and ran a couple minutes and tripped again. This happened another couple times and I pulled some fuses and checked and they're all good. It's going now with the compressor just staying on with temp set at 73 in the bunk. Noticed the cooling or radiator fan for apu isn't coming on though. I'm missing the cover that identities what fuses are what for the fuse box of the apu. Does anybody happen to know where to find one?
    I did notice a little blue spark on some fuses when the blades would hit the fuse terminals putting the fuses back in. Not sure if that means anything. I'm mechanically stupid. Not being modest.
  8. Stringb8n
    1,705
    2,232
    Sep 27, 2015
    I foundadid my problem. It was the wire with the inline 5amp fuse in battery box. Can't seem to get the dang butt connector tight enough or something. But redid the connection yet again and so far so good. FYI, that wire WILL cause you hell if or when you have problems with it. Got out and wiggled the connector on that wire (butt connector) after it threw ENG code again and I reset the breaker. Ticked it's ### off like a dead battery again. That's how I figured that was the culprit.
    Siinman Thanks this.
  9. maneri1891
    maneri1891 Bobtail Member
    31
    Jun 30, 2019
    Did that sensor fix it?
