APU main fuse question!
Discussion in 'Volvo Forum' started by Tuzla075, Dec 13, 2013.
  1. Tuzla075
    Tuzla075 Light Load Member
    60
    17
    Dec 4, 2012
    Just wondering if this is that main fuse for the APU! see the pictures! My display wont turn on, and couple of guys here mentioned to check main fuse by the alternator! Some are saying that this fuse is on the batteries! So Just to make sure if somebody knows if I need to change this one on the picture!?Thanks!
  3. Tuzla075
    60
    17
    Dec 4, 2012
  4. KW Cajun
    KW Cajun Road Train Member
    2,383
    3,652
    Apr 12, 2013
    Copperhead Road
    Not a Volvo expert, but there's a possibility that that fuse goes to an inverter, if not, then most likely your APU.
    I'd test it with a continuity tester first, before replacing it.
    Tuzla075 Thanks this.
  5. luvtotruck
    luvtotruck Road Train Member
    1,978
    1,161
    Jul 30, 2013
    Phoenix Arizona
    He beat me to it! But follow the wires down. I think that may be the problem, That one side doesn't look very good... But what do I know. I hope you get it fixed.
  6. skateboardman
    skateboardman Road Train Member
    6,232
    5,706
    Jan 14, 2012
    flatbed heaven
    my apu has a fuse like that in the battery box, that joker is corroded for sure , clean it . a baking soda paste will work well. if the main line going to the batteries get corroded the apu wont start and will be dead, clean it and all other connections in there while you are at it.
  7. Tuzla075
    60
    17
    Dec 4, 2012
    Thanks for the info guys!!!
    Do you know by chance where is the easiest place to get this kind of fuse? I noticed there is a thin white wire on the bottom of the APU, and its kind of exposed of isolation( is this the ground), but very hard to get to it.
