Or something else? I am looking to buy brand new and also looking for anecdotes from experienced people with their money on the line. Personally my experiences with Tripacs have been dreadful, Carrier less so. Very limited in mechanical skills but I can change the oil lol.
APU: Tripac or Carrier?
Discussion in 'Ask An Owner Operator' started by Driver Eight, Jul 11, 2021.
Page 1 of 3
I absolutely love my carrier unit- I’ve had 3 tripacs and there’s no comparison- the carrier unit is a full on generator that runs a electric climate unit- it’s a sealed ac compressor for cold and a heat grid for heat- the unit outside is a kubota engine driving a 6k generator- with the tripacs I was eating chassis batteries by running hotel loads off the inverter- with the carrier I run hotel loads off the 120 outlet tied directly to the generator- only pain is when you have unit set to high heat it shuts off the 120 outlet because of the high draw of the heat grid- I usually run high till the sleeper is up to temp- then set it to low heat and it maintains temp all night
86scotty, Jarhed1964, autopaint and 2 others Thank this. -
Only draw back to that generater is that when it fails it isn't cheap , mine was 1200.00 but it also had 15500 hours on it .
Also when I had it replaced I got rid of that stupid link belt and upgraded it to a serpentine belt .shooter19802003, slow.rider and Jarhed1964 Thank this. -
Carrier all the way. Mine on my truck will be transferred to my new truck in Dec this will be the 3rd truck it will be installed on. Somewhere around 19k hours on it.
I change my oil on it when truck gets serviced. Some times 300 hours some times 500 hours. Never more than 700 hours. Yes I know I am wasting money but $13.00 in filters and a gallon of 15/40 delvac. I change belts and tensioner every 3000 hours. Both belts. I have done 4 valve adjustments, 1 injector, 2 coolant pumps both glow plugs 3 times. 1 alternator and Generator. Do the work myself. Not a hard unit to work on unless it’s on a truck and mounted behind fairings or some such thing. Easier to get at just peer top snd bottom covers off.
whole cabinet comes off really easy and most everything is accessible.black_dog106, shooter19802003, slow.rider and 3 others Thank this. -
If I were to ever be In the truck enough to need one, I would just go roof top or mini split with a Honda generator, you can buy 5 of them for the cost of an apu that will be junk by the time you break even
main problem with APU no one wants to maintain them. Not sure why but they are cheap and easy to maintain. But then again some of these idiots out here can be bothered to bathe regularly or throw trash away properlyLast edited: Jul 12, 2021
shooter19802003, slow.rider, mitmaks and 2 others Thank this. -
slow.rider, jason6541 and Midwest Trucker Thank this.
My next new truck spec (if it ever happens) will be Espar heat, Carrier generator, mini split AC from day one.shooter19802003, slow.rider and bzinger Thank this. -
I like with the carrier I get the option of running it start stop or continues.
slow.rider Thanks this.
Page 1 of 3
