APU Weight Exemption on Which Axle(s)?
Discussion in 'Experienced Truckers' Advice' started by PE_T, Dec 25, 2018.
  1. PE_T
    PE_T Road Train Member
    Some say their company states the excess weight should go on the steer axle and others say the drives? Does the APU weight exemption law mention this? It seems like they forgot to mention where to place the excess weight.
  3. flood
    flood Road Train Member
    4,169
    4,051
    Dec 25, 2010
    it doesn't say.
    PE_T Thanks this.
  4. dptrucker
    dptrucker Road Train Member
    4,707
    3,250
    May 14, 2012
    adelanto,ca.
    Since most of the apu I see are mounted by the catwalk. I would think.most of that weight would go on the drives
    bzinger and PE_T Thank this.
  5. Moosetek13
    Moosetek13 Road Train Member
    15,004
    19,065
    Nov 1, 2010
    Burnsville, MN
    Maybe it is for gross weight?
    Bean Jr., flood, PE_T and 1 other person Thank this.
  6. Tb0n3
    Tb0n3 Road Train Member
    4,742
    9,662
    Oct 5, 2012
    Earth
    I do believe it is gross. Just has to be legal on axles iirc.
    Bean Jr. and PE_T Thank this.
  7. ZVar
    ZVar Road Train Member
    10,911
    23,833
    Sep 10, 2010
    Flint, MI
    The federal suggestion states axle or gross. It really doesn't matter which axle, as long as you are not going over the mechanical limit. I.E. you are still limited to 12k on most fleet trucks as that is the axle weight. 12.5k and 13k for some trucks, again depending on the physical axle.
    Here is a list by OOIDA of which states allow how much weight. Also, make sure you have the weight certification in your paperwork. That's what allows the exemption.
    Vehicle weight exemptions for APUs, Owner-Operator Independent Drivers Association
  8. PE_T
    Wouldn’t this defeat the purpose of the APU weight exemption law as most trucks on the road are designed for 12k steers and 34k drives? I need to check my truck to make sure what really is the rating for my steer axle and drives.
    flood Thanks this.
  9. ZVar
    10,911
    23,833
    Sep 10, 2010
    Flint, MI
    Most fleet trucks the steers are 12k yes. At least everyone I've ever been in.
    The drives, on the other hand are typically rated for 40k (20k per axle). It's just Interstate system limits to 34k. A lot of states allow more on state roads.
  10. PE_T
    Everyone is sweating over 300 or 400 pounds overgross when it’s very possible most weight stations wouldn’t care and are looking for the real outlaws who are 1,000 or more overgross.
    Ffx95 and ZVar Thank this.
  11. flood
    4,169
    4,051
    Dec 25, 2010
    my steer axle is rated at 12,300
    PE_T Thanks this.
