APU with no space on the frame
Discussion in 'Experienced Truckers' Advice' started by MGE Dawn, Mar 16, 2024.
  1. MGE Dawn
    MGE Dawn Road Train Member
    1,098
    2,294
    May 19, 2019
    Vancouver, WA
    I'm probably not the first person to ask this, but I haven't been able to find another thread that addresses it.
    I'm looking to install an APU on my truck, but it lacks usable space on the frame rail to mount most of the options I've come across (thanks, mid-2000's Volvo). Ideal solution would be a unit that either:
    - Is small enough to fit between my frame rails and the aero kit that Volvo used in the mid to late 2000's that spans the space between the fuel tank and the quarterfender, or;
    - Can be mounted on my catwalk without interfering with the swing of the nose of the trailer
    Is anyone aware of a decent option that can solve this dilemma? If so, y'all willing to share your knowledge? Thanks in advance!
  3. Coolbreezin
    Coolbreezin Medium Load Member
    408
    439
    Jun 11, 2016
    Florida
    Depends on what services you are wanting from the APU. A mini split or RV roof a/c operated off of lithium phosphate batteries can resolve temperature issues. If its battery charging while away doing hometime, then a solar panel on the dash kit with charger resolves that. Was there anything I didnt think of?
  4. Thrasher28
    Thrasher28 Road Train Member
    1,246
    3,549
    Aug 12, 2021
    Bowling Green, KY
    II keep getting Facebook ads for the HP2000 APU. Don't know anything about its reliability or cost, but it is compact based on the pictures.
    Our fleet of newer gen volvos has just a typical Carrier APU behind the side fairing, but not sure the clearance difference and fuel tank size would matter too.
    Here's the HP2000 though: 1570807712615.jpeg
  5. pavrom
    pavrom Road Train Member
    3,216
    7,408
    Apr 29, 2012
    NE illinois
    get smaller fuel tank to fit apu
  6. 86scotty
    86scotty Road Train Member
    4,710
    12,929
    Aug 27, 2017
    Appalachia
    I haven't posted pics because I still haven't mounted my outside unit but that's exactly what I've done. 560ah of lithium and a 2500 watt inverter under passenger side bunk and 9000 btu mini split. My truck already has a Webasto heater and factory inverter on the driver's side to handle heat and house needs.
    The only thing I don't have is a coolant loop/block heater solution but I don't need it where I run. YMMV.
  7. Arctic_fox
    4,511
    25,503
    Sep 16, 2016
    Depends on how creative you want to get and how much actual room you have. In many cases there is room to slide a fuel tank forward or you can remove the catwalk step. There is often room behind the ferrings you can use or you can as someone else recomended get a smaller fuel tank. You can directly mount them against the cab on the catwalk (this can be really loud though). RV ACs, battery powered mini splits and more.
    Also some brands are much thinner then others. My green for example is a good 9 inches narrower then a comparable thermocant. I have even seen some guys cut their fender off and put a chunk of metal on the side of the APU and use the APU itself as a fender.
  8. krupa530
    krupa530 Light Load Member
    296
    1,140
    Dec 3, 2014
    Orem, UT
    Lithium is definitely the way to go. Prices have come down considerably in just the last year. Epoch are now doing a 460AH heated battery for $2000. Guaranteed for 11 years too. Just put a dc to dc charger on to charge it. Pick up a roof mount 12v ac for under 3 grand.
    Look at the van life crowd forums and you’ll get plenty of ideas.
  9. MGE Dawn
    1,098
    2,294
    May 19, 2019
    Vancouver, WA
    I'm already running twin 100's... I honestly couldn't go any smaller than that without putting myself into multiple bad situations
    austinmike Thanks this.
  10. MGE Dawn
    1,098
    2,294
    May 19, 2019
    Vancouver, WA
    Oh, you know... climate control, battery charging (both at home and on the road)... dunno if it's feasible to use the APU as a block heater since mine seems to be INOP or to use it for power in the truck, but if both of those are feasible, then I'd like those services as well. My big thing is that I have a number of issues I'd like to solve with as little added weight that can't be covered by the APU exemption as possible, y'know?
  11. loudtom
    loudtom Road Train Member
    1,717
    2,806
    Aug 26, 2016
    If you're trying to save weight and increase space, why not just get a single 150 gallon tank on the driver side and free up the entire passenger rail? That's how our truck is set up, and we haven't run across any fuel problems running a team truck. It's also kind of nice not having to worry about the satellite pump every time we fuel.
