APU's and or Inverters?
Discussion in 'US Xpress' started by HD_Renegade, Jul 21, 2011.
  1. HD_Renegade
    HD_Renegade Road Train Member
    1,470
    607
    Dec 20, 2010
    North Carolina
    Does USX have APU's in all of their trucks?
    Do they have an Inverter or do you can you supply one?
    What do they have for Idling rules??
    Thank you
  3. WX4JCW
    WX4JCW Light Load Member
    161
    67
    Nov 20, 2009
    Orlando, FL
    No Apu's yet . They are "looking" at the battery powered type but not holding my breath
    They will allow up to 1750 on inverters but the terminal has to install it but it's free you just buy the inverter
    Idling rules are tighter with no idling in the terminals
    Sent from my iPhone using Tapatalk
  4. HD_Renegade
    1,470
    607
    Dec 20, 2010
    North Carolina
    If you are stuck at a Terminal and it is 90+ degrees outside, you can't Idle???
  5. flood
    flood Road Train Member
    4,169
    4,051
    Dec 25, 2010
    if it's above (don't quote me) like 75 you can idle or below 50
  6. musicgal
    musicgal Road Train Member
    1,171
    467
    Mar 8, 2010
    Carthage, Missouri
    They are discouraging the idling of trucks when the weather is nice......it's like Flood said, above 75 or below 50
    Shardrk Thanks this.
  7. HD_Renegade
    1,470
    607
    Dec 20, 2010
    North Carolina
    Sounds like it might be do-able. I could see lowering the 75 to about 70, and even lowering the 50 to 40 too.
  8. NoCoCraig
    NoCoCraig Road Train Member
    2,604
    1,695
    Nov 7, 2010
    Chattanooga, Tennessee
    All of the newer trucks have bunk heaters so you do not need to idle for cold weather, just for hot
  9. WRIGHTRACING
    WRIGHTRACING Heavy Load Member
    882
    251
    Jan 3, 2011
    Iuka MS/Muscle Shoals AL
    So what is the reason a company of this size does not have APU's and built in inverters? I mean the APU's save all kinds of money for idling, and the built in inverters are just commonplace now, or so I thought.
  10. flood
    4,169
    4,051
    Dec 25, 2010
    invertors are optional so usx doesn't order them but if you want one they will intstall yours up to a 1750w for free. as to the apu's usx has checked and thay realy don't save as much as you thing they do.... what the apu makers say they use in fuel is not real world numbers, some clam .1 gl per hr...! a bunk heater uses that much some say .25 gl per hr. NO-LOAD almost all use .4-.6 gl per hr with the ac running and some the ac will not cool the cab AND sleeper (you need to close the curtain to keep the sleeper cool) and they add around 400 lb to the truck.
    my volvo uses .5-.6 gl per hr to idle with the ac running so for my truck i would save MAYBE 2 gl a day and i idle for around 150 days so i may save 300 gl a year at $3.50 a gl i would save around $1050 and the apu will cost $8,000-$10,000 installed so it would take what about 7 years for it to realy pay for itself and the electric apu's are just as bad they weigh as much and the batteries only last about 2 years so you are spending $200 a year on batteries and on a good day they only last 10hr's. if your on a 34 you will need ti idle the truck for 16-18 hr's to charge the batt.
    did we mention maintenance on the apu...?
    don't you think a company the size of usx wouldn't do anything they could to save money... they put $800 camara systems on all the trucks to save >.1 mpg in fuel, they put in bunk haters that use .1 gl per hr to keep the truck warm.... the return on an apu is to slow, and i was part of the apu test a few years ago
  11. WRIGHTRACING
    882
    251
    Jan 3, 2011
    Sorry if I have to disagree, but you mean to tell me, a little maybe 2litre motor, uses almost the same fuel as a 15 litre motor idling???:confused::confused:
