From what I’ve read everyone who has ever owned a Transcraft trailer has had problems with cracking. Does that go for all of their flatbeds? Certain years that are bad? Are their steel/aluminum trailers less prone to cracking than all aluminum’s? The other way around? I ask because there’s a few for sale close to me, and I’ve been avoiding them like the plague due to what I’ve seen people say online.
Are all Transcrafts bad?
Discussion in 'Flatbed Trucking Forum' started by Gumper, Mar 16, 2018.
Page 1 of 7
I have a transcraft in my yard. it's a 2000. it had one crack, which I caught and fixed. all trailers are prone to cracks.
Transcraft does seem to crack sooner than later.
if you buy one look at the spot just in front of the front axle to frame location.
being proactive you can still make a buck with a transcraft.
then save up for the one ya wantHopeOverMope Thanks this. -
Maybe with the combos. I’ve had 3 all steel Tanscrafts 2 steps 1 flat. the flat was an 05 the steps are 10 and 11 no cracks on any of them.
Just depends what you're using them for. Guys that run 45k plus steel coils every day will have more cracking issues than guys that haul general freight. They sold a boatload of them before aluminum took over around here so I wouldn't say their all junk. Just try to get a heavy spec one thats done light work all its life. Easy right?
Airborne, Grubby, peterbilt_2005 and 1 other person Thank this. -
Really don’t see myself hauling coils.
Debating buying a so-so flatbed now and paying cash, and getting a nice one down the road, OR financing a nice flatbed right off the bat. I let two nice trailers for not much money slip away since my truck wasn’t ready.
Have run both 48 and 53 transcraft trailers.
The 53 was fixed spread set for cali.
This was a combo, steel frame, aluminum deck with nailers. Slide winch.
It seems the 53s are the most prone to problems.
Cracking in the rear, around the suspension mounts is very common. Have seen a few that cracked where the taper on the front is, just behind the king pin frames. Keeping wheel alignment seems to also be high on the list. Rub rail and stake pockets are prone to breakage or bending with very little force.
My guess on the 53s and the problems are related to construction. If you look at the frame, the rear section seems to be an add on. Like they just welded on and extra 5 ft to a 48.
The 48s have been better. Still have rub rail and stake pocket problems. Same wiring problems. -
That doesn’t sound very appealing
Transcraft units are more than adequate for general flatbed freight. Only reason not to buy one is weight and corrosion issues. There are millions and millions on the road every day.
My money says to buy new right out of the gate. I bought used and wish I bought new first. That being said I have refurbished this used unit for about $6k over the last 2 years to be in decent shape now. Can’t justify buying new now but if I had it to do over would of bought a NEW Mac right out the gate. Even though I only spent $13k on my new to me Truck.DSK333, Ruthless, peterbilt_2005 and 2 others Thank this. -
Page 1 of 7
