Are Type 20 Brake Chambers Normal on an '88 378?
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Hilltop Hustler, Jun 2, 2025.
  1. Hilltop Hustler
    Hilltop Hustler Light Load Member
    79
    52
    Apr 29, 2023
    West Virginia, USA
    My resto pete project has 30/30 brake chambers on the front drive axle and the rear drive axle has type 20 brake chambers. Is this normal for this year make and model? I was looking at pictures of another 378 that had the same set up and I'm curious if i should just keep it as it is.
  3. Oleg D
    Oleg D Bobtail Member
    24
    12
    Jun 29, 2021
    Canada
    Hey I'm trying to start new thread and can't figure out how. How did you start yours
  4. wore out
    wore out Numbered Classic
    17,777
    223,389
    Jun 5, 2013
    CHASIN THE DEVIL'S HERD
    It should have 30’s on the rear axle and 24’s on the steers. The front drive will be only one with 30/30 or park brakes
  5. Hilltop Hustler
    79
    52
    Apr 29, 2023
    West Virginia, USA
    Thanks bud. New to a lot of the diesel side of wrenching
    Oxbow Thanks this.
  6. ElmerFudpucker
    7,374
    80,815
    May 17, 2024
    That’s a type 30. 30/30 references the park and service diaphragm size. Type 30 is a single 30 square inch service chamber. Type 20 is likely on the steer axle. And yes it was common to only have one parking axle.
    Diesel Dave and Oxbow Thank this.
  7. MRMTRANS
    MRMTRANS Medium Load Member
    411
    441
    Apr 28, 2015
    I had a 1998 FRTL 132 XL (Classic) that had no parking brake chambers on a rear axle. One time the truck started to move after setting the brakes on a hill and weighing 80k+ lb (probably 85-90k of bulk potatoes, lol). That's when I figured it was time for new brake chambers
    Rideandrepair Thanks this.
  8. AModelCat
    166,439
    Was that an older truck thing or is it still common having spring brakes on only one drive axle?
    Just curious, never seen it before.
  9. ElmerFudpucker
    7,374
    80,815
    May 17, 2024
    Most new trucks come with parking brakes on both axles. I don’t think there is any law, just that’s how they are spec’d now
  10. SmallPackage
    5,863
    18,825
    Dec 20, 2019
    Marion Texas
    Depending on make of truck and suspension spec’d as to what axle they were on. Pete air rides they were on front drive. KW air rides they were on rear drive. I’ve seen FL’s either way. Having 30/30’s on both axles was an option. Pete used to call it the full Ankorlock option on the sales orders in the late 60’s and 70’s. MGM/Ankorlock was the oem supplier to paccar back then. 100% servicable All aluminum body chambers.
