Assembly vs kits vs real product.
Discussion in 'Ask An Owner Operator' started by Ikamob01, Oct 24, 2022.
  1. Ikamob01
    Ikamob01 Medium Load Member
    314
    195
    Dec 4, 2021
    Guys I'm trying to buy a part but it says assembly. It looks like the actual product. Can someone educate me on this issue?
    What are the differences?
    see example below
    Wabco 4006120100 Trailer Abs Kit 2S2M 4S3M[​IMG]
    HALDEX 4005001030X - Trailer ABS Valve and Electronic Control Unit Assembly - Reman, Dual Trailer with ECU
  3. nikmirbre
    nikmirbre Road Train Member
    5,590
    10,358
    Jul 27, 2011
    High Point NC
    I believe that "assembly" just means the part you're trying to buy such as......
    The red and yellow brake buttons....... the piece behind the dash is the "assembly"
    Its hard to explain some things lol.......
  4. Ikamob01
    314
    195
    Dec 4, 2021
    Sought of the case...right?
  5. Terlingua
    Terlingua Medium Load Member
    487
    1,021
    Oct 24, 2021
    When an automotive part is sold as an "assembly," it means you're buying something that's composed of multiple individual parts that are already put together to form some larger component. You may or may not be able to buy each of the individual parts separately. It's frustrating when you have to buy an expensive assembly to get the one piece of it that actually broke. In your example, it's probably being called an assembly because it includes both the valve and ECU.
  6. Ikamob01
    314
    195
    Dec 4, 2021
    I ended up buying the one that doesn't need to be programed,
  7. MWTechGuy
    MWTechGuy Bobtail Member
    17
    6
    Nov 8, 2022
    The part numbers break down what you have. The "X" at the end means that it is a reman part by HALDEX, since this is a WABCO valve but is sold as a reman by Haldex, that would be the difference. WABCO also sells reman as "X" or "7" at the end but then it would have been rebuilt by them vs the one you are looking at is a WABCO valve rebuilt by Haldex. I think that's the major difference here.
