Authorized fuel up spots?
Discussion in 'TMC' started by Gunner75, Apr 30, 2014.
  1. Gunner75
    Gunner75 Road Train Member
    5,701
    9,076
    Mar 17, 2014
    Jackson Center Ohio
    Just curious what places TMC allows drivers to fuel up at? Im assuming like most places, TA's, Love's, Pilot/Flying J. Do they allow you to fill up at places that arent one of the big ones?
  3. bad-luck
    bad-luck Road Train Member
    3,458
    6,381
    Nov 16, 2013
    Baltimore, Maryland
    by this question I'm assuming that you work for tmc . Ask your dm or check your driver packet and it sgold give you all the information that you need
  4. Gunner75
    5,701
    9,076
    Mar 17, 2014
    Jackson Center Ohio
    Not yet, but soon
  5. MinniesB
    MinniesB Light Load Member
    90
    37
    Sep 16, 2012
    Poplar Bluff, MO
    Mostly pilot/flying j is our fuel network... Only fuel out of network if there aren't any of those around and for that you need authorization
    Gunner75 Thanks this.
  6. riverrat143
    riverrat143 Light Load Member
    146
    113
    Jul 14, 2009
    Brodhead, Wisconsin
    There is a lot that goes into this besides just locations. Typically, you will get a location and how much fuel to put on along with your load screen. You are expected to hit a certain percentage of your advised fuel stops. Otherwise it lowers the score you need to move up in pay. You will find that if you follow the fuel stops that TMC gives you, you will most likely load with about half tanks or less and add fuel after you have loaded. TMC pulls a lot of heavy freight and they don't want you going into a shipper with full tanks and have to put 48000 on the trailer. Fueling after you load depends on how heavy you are.
    Your trainer will explain this to you during your 5 weeks with him.
    Gunner75 and bubbagumpshrimp Thank this.
