Auto neutral problem
Discussion in 'Ask An Owner Operator' started by PstTrucking, Apr 21, 2025.
  1. PstTrucking
    PstTrucking Bobtail Member
    10
    Apr 20, 2025
    I have a 2019 international 4300. I went to reverse and a message popped up on the dash saying auto neutral. Truck wouldn’t move or shift outta gear. Finally got it into park and wouldn’t shift from park. Turned truck off and now the dash just says N meaning neutral I’m guessing and truck won’t start. Any suggestions??
  3. North Pole Nightmare
    North Pole Nightmare Road Train Member
    1,015
    2,087
    Dec 15, 2021
    Turn your batteries off a few minutes,might reset.
  4. DUNE-T
    DUNE-T Road Train Member
    7,058
    17,196
    May 10, 2015
    Detroit, MI
    See if it has Neutral Relay in Fuse box, remove and attach, see if that helps. You gotta take it to a mechanic though, it can be all kinds of things to cause that problem
  5. North Pole Nightmare
    1,015
    2,087
    Dec 15, 2021
    We got a 2021 KW T680 that sat unused for about a year.Had 150,000 miles on it.The transmission started doing that auto neutral, had to shut the truck off,switch the master switch off,then restart in order to move.When it did it the first time I stopped at the KW dealer in Cheyenne and he said you have to change out the air dryer filters once a year,or that problem comes up. After 12 times having that issue they changed the transmission and filters,fixed it.
