Autoshift problem
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Alotajs, Feb 17, 2015.
  1. Alotajs
    Alotajs Bobtail Member
    6
    Hey guys,
    mI have an 07 Pete with an 18 speed eatin autoshift in it. It got stuck in 7th gear and I have no lights at all on the gear selector. Pulled over, shut it down, tried resetting ecu, disconnecting batteries etc. and still have no lights on the selector and an f on the display with a -. Now im stuck on the side of the road. Any ideas?
  3. Alotajs
    6
    Thanks, but my issue is that there's no power going to the actual shift tower. No answers in that thread
  4. RSQ20
    RSQ20 Medium Load Member
    You must have good/clean battery power to the transmission control module, there are 2 supplied
    1.direct/fused from battery bank,
    2.switched from ignition key..
    Both must be full power, no more than .5vdc difference from main battery bank..
    ... Philip
  5. russtrucker
    russtrucker Road Train Member
    1,767
    337
    Mar 27, 2012
    Central PA
    That is the big reason why i wouldn't take ultrashift, autoshift, or i-shift. Manufacturers target big fleets so they can come back to the shop daily with ecu issues.
  6. Jerry12
    Jerry12 Heavy Load Member
    723
    282
    Sep 9, 2014
    Tranny is not shifting out of gear, take it the dealer for them to diagnose. (possible issues: sensor(s), tranny's power harness, trannys wiring harness going to sensors, x-y shifter, alternator-starter power cable, loose bolt on the trannys output shaft yoke...musing)
  7. swaan
    swaan Road Train Member
    2,942
    4,374
    Jul 12, 2009
    BC canada
    Yup. Autoshifts are fantastic aren't they. Lol
  8. russtrucker
    1,767
    337
    Mar 27, 2012
    Central PA
    So fantastic for repair bills than manual.
