Auxiliary air tank
Discussion in 'Volvo Forum' started by palmeris, Aug 2, 2025.
  1. palmeris
    palmeris Bobtail Member
    36
    18
    May 18, 2023
    Truck has the 3 factory tanks, and on the rear drivers side by fuel tank is a small 5 gallon air tank. Has an input and out put.
    One has a pressure regulator, presumably the output line.
    Truck does have air slide 5tth wheel and air pin decoupler, 2 buttons on dash.
  3. AModelCat
    166,503
    Probably a pressure protection valve.
    Big Road Skateboard Thanks this.
  4. palmeris
    36
    18
    May 18, 2023
    Yes. I should be more specific , what is the tank used for? I dont know that it is for the 5th wheel functions or something else? What Resized_20250622_151219.jpeg would the regulator be protecting?
  5. palmeris
    36
    18
    May 18, 2023
    Also another question if anyone knows what is the thread type on the factory tanks? Thought it was 3/8 mpt but it won't thread in
  6. wichris
    wichris Road Train Member
    4,656
    9,726
    Jan 17, 2011
    Doesn't allow air out of the tank until 60-70 psi. Usually to the leveling valve, air slide ect.
  7. palmeris
    36
    18
    May 18, 2023
    Oh, so more of a control valve that opens at a specific pressure rather than a pressure regulator that doesn't allow anything over a specific psi?
  8. Big Road Skateboard
    7,868
    45,803
    May 2, 2021
    Some Stars had an Aux air tank specifically for the auto trans. I'm sure some FL's did too, but I only ever saw them on WS.
    Possibly that? Sure enough, if you follow that air line you'll know for sure
  9. palmeris
    36
    18
    May 18, 2023
    It's on a 2019 vnl860.
    Lines are in a huge bundle of other lines,cables, etc and I loose track of them. would have to cut open a bunch of zip ties and such to separate and follow them but both in and out appear to route towards the front main tanks along the frame rail.
    Is it a for sure the regulator is on the output line?
  10. JB7
    JB7 Road Train Member
    1,173
    2,219
    Dec 13, 2022
    Laurel, MD
    Here's a short video. Need to pull something out that is screwed into the tank.
    Bing Videos
    Chart came from here.
    Air Line Fitting | Volvo Trucks USA
    More here. This has all the air tubing and fittings with part #'s.
    volvo-section-5-brakes.pdf
    palmeris Thanks this.
  11. Big Road Skateboard
    7,868
    45,803
    May 2, 2021
    Like others have said, it's a pressure protection valve.
