Auxiliary lights (chicken lights)
Discussion in 'Ask An Owner Operator' started by Adriantx, Jun 27, 2022.
  1. Adriantx
    Adriantx Light Load Member
    64
    17
    Dec 29, 2018
    I have bumper lights side mirror lights and sleeper side panel lights all installed by me. Dose any one know how to connect them to make then flash along with marker lights when pressing botton we press to say thanks when someone flashes you over? Don't know what the botton is called.
  3. bad-luck
    bad-luck Road Train Member
    3,439
    6,332
    Nov 16, 2013
    Baltimore, Maryland
    It's commonly referred to as an interrupt switch. You will need to purchase and install the switch on your dash, and run the hot and ground wire to the switch.
    RefMata Thanks this.
  4. abyliks
    abyliks Road Train Member
    4,123
    9,716
    May 2, 2010
    ludlow MA
    Spring loaded toggle switch to replace the factory one, or just flip the switch on/off
