Auxiliary / transfer fuel tanks
Discussion in 'Trucking Industry Regulations' started by Bdog, Feb 6, 2021.
  1. Bdog
    Bdog Road Train Member
    1,057
    877
    Nov 6, 2014
  3. 062
    062 Road Train Member
    6,346
    34,006
    Oct 20, 2013
    Just for clarification. Will it be used for fueling other equipment or add capacity to the truck?
    kemosabi49 Thanks this.
  4. Bdog
    1,057
    877
    Nov 6, 2014
    Potentially both.
  5. 062
    6,346
    34,006
    Oct 20, 2013
    You could remove the step box on the right side and put a tank there. @cke has tanks under the door. Maybe he can give you a idea of the capacity and dimensions.
  6. Bdog
    1,057
    877
    Nov 6, 2014
    This is going on a Mack. There isn’t a place there for a tank. I have plenty of room on frame rails on top.
    062 Thanks this.
  7. Diesel Dave
    9,732
    33,335
    Jan 20, 2010
    Hesperia, Ca.
    I’ve seen those kind of set up’s, behind the cab, usually PTO(Hydraulic oil) set up. I don’t know if it would be legal for fuel.
  8. snowwy
    snowwy Road Train Member
    20,612
    13,333
    Jul 6, 2009
    Is there a law on fuel tanks? And position.
  9. Ridgeline
    22,752
    124,021
    You can use it as long as you have a tank that will not splash fuel onto any part of the exhaust or related equipment if overfilled.
    fmcsa 393.67 ...
    BoxCarKidd Thanks this.
  10. SmallPackage
    5,818
    18,636
    Dec 20, 2019
    Marion Texas
    Legal and has been done for years. Couple of trucking company’s out of Houston ran them during the Alcan Pipeline Construction. Gave them more range.
    A slick thing you can do is since it will be sitting higher than the side tanks is plumb hose into a fitting on the top of one of the side tanks were a return line goes and a shutoff valve on the aux tank. When low open valve and let gravity feed the other tank. You won’t need a pump.
  11. Allow Me.
    10,779
    12,629
    May 28, 2009
    Rancho Mirage, Ca.
    I remember a couple co's did that back in 70's/80's. Two 150 gal saddle tanks plus 3rd tank on frame rails. #### near made coast to coast run without stopping for fuel. I believe their mindset was not paying truck stop prices for fuel and wasting time fueling too.
    Diesel Dave Thanks this.
