Axle housing swap
Discussion in 'Trucks [ Eighteen Wheelers ]' started by dziubak, Jun 13, 2022.
  1. dziubak
    dziubak Bobtail Member
    16
    6
    Dec 27, 2012
    I have an old kenworth with an AG100 suspension. One of the SQHD rears went out and I’m thinking now may be the time to put some lockers on it. I’m looking for a cutoff I can swap over. What are my options? Can I get a cutoff from a walking beam truck, other air glide systems like 200, 400, 460, from other manufacturers trucks, or am I stuck swapping from an AG100?
  3. spsauerland
    spsauerland Road Train Member
    4,296
    10,891
    May 31, 2010
    West Harrison, In
    Best to find cutoff that has same frame thickness, height, and width.
    n4ane Thanks this.
  4. BoxCarKidd
    BoxCarKidd Road Train Member
    4,560
    6,646
    Aug 26, 2014
    Get rid of the AG100. At least all of the connecting arms and center bracket.
    Some folks can put most anything together.Good ones are getting rare. Insurance companies do not want to cover them. Good ones with insurance are expensive.
  5. AModelCat
    165,219
    You can put whatever you want on there. If you're splicing the frame, find something with the same size rails and graft it on.
    spsauerland Thanks this.
  6. dziubak
    16
    6
    Dec 27, 2012
    I understand that I can put anything I want on there. I was hoping to not have to drill more holes in the frame than what’s already there. That’s why I was wondering what rear end housings I can bolt up to what’s already there. The center bracket and arms have already been replaced so I was hoping to just swap rear housings out.
  7. AModelCat
    165,219
    Any housing that was once mated to an AG100 will be easiest. Otherwise you'll more than likely have to cut and weld new brackets to the housing, which is not exactly straightforward. A few special processes are involved when welding axle housings.
    n4ane Thanks this.
