axle weight tolerances?
Discussion in 'Flatbed Trucking Forum' started by snowman_w900, May 9, 2016.
  1. snowman_w900
    4,418
    81,025
    Nov 25, 2010
    anyone know how Tennesee is on axle weights? do they allow much or any tolerance on trailer axles? Kentucky usually doesn't harass me until about 5% over axle. I'm about 800lbs over on my spread.
  3. JAYRODPA
    JAYRODPA Light Load Member
    157
    109
    Dingmans Ferry pa
    General rule is less then a thousand over axle as long as it isn't over gross.
    snowman_w900 Thanks this.
  4. snowman_w900
    4,418
    81,025
    Nov 25, 2010
    thank ya jayrod....im 78400 on my gross. I don't run TN much. just wondered how picky they were.
  5. justa_driver
    justa_driver Road Train Member
    1,105
    817
    Apr 2, 2014
    Tennessee
    Ive never had TN bother me as long as I wasnt over 1000 lbs but if they do get you, they give you 2 tickets- one for the County and one for the State.
  6. Md420
    Md420 Medium Load Member
    469
    559
    Nov 2, 2015
    Tn
    I live in TN. If you are going down 75 through Knoxville or I81 they will bust your ###. You can run 75 to Knoxville and get over on us411 and run all the way to dalton ga with no scales
    Chewy352 Thanks this.
  7. MACK E-6
    50,138
    239,502
    That's what MD allows, but not on Interstate highways.
  8. justa_driver
    1,105
    817
    Apr 2, 2014
    Tennessee
    Nope not nervous in the service. LOL Kinda slow though with xp:D
  9. MACK E-6
    50,138
    239,502
    Just an FYI.
    That will change every time you load the page. ;)
  10. justa_driver
    1,105
    817
    Apr 2, 2014
    Tennessee
    Yea I was jus pickin at ya. Im on my backup. I had 7 in my other one and I put 10 in it and still trying to figure it out. LOL
  11. ChaoSS
    ChaoSS Road Train Member
    3,338
    6,758
    Sep 20, 2014
    First off, I've never had a ticket so take what I say with a grain of salt, but I've heard cops can be a bit less forgiving with spread axles, just because you already have so much more wiggle room that they figure that you should be able to get it legal.
    Also, have you scaled each axle individually? 800 pounds over, I'm assuming you have a full spread, puts you at 40800. If your leveling valves aren't working properly (and when I scale my axles individually, most of the time I am close but rarely are they dead on equal, and I pull a lot of different trailers) you could have all of that excess on one axle. You could have one axle at 19000 and one at 21800. If I were you before I even thought of risking it I would make sure I had accurate axle readings.
