Back up light not working. 2015 cascadia
Discussion in 'Freightliner Forum' started by Broccelli, Dec 22, 2014.
  1. Broccelli
    Broccelli Medium Load Member
    Jan 2, 2014
    373
    Thanks Received:
    198
    Virginia
    Just wondering if anyone knows of a fuse for the backup (reverse) light. I've replaced the light and it still will not work. Can't find anything in my manual in regards to a backup light fuse. Also is there a switch on the transmission? If anyone has any idea what it could be I would appreciate any info. I'd prefer not to have to waste my time at the dealership if I can.
    P.s. If it makes any difference it has a manual trans (eaton 9).
  2. dog-c
    dog-c Road Train Member
    May 30, 2011
    1,852
    Thanks Received:
    1,546
    New York, NY
    unbelievable -- a truck that costs $145,000...........lmao
  3. Broccelli
    Jan 2, 2014
    373
    Thanks Received:
    198
    Virginia
    Very helpful. I appreciate your input. Btw if I have any problems that I can't track down with my other truck I'll just pm you so you can give me an appraisal on that truck too.
  4. blairandgretchen
    Dec 9, 2011
    13,641
    Thanks Received:
    74,150
    South west Missouri
    You can absolutely count on the forum users for helpful advice. :biggrin_25523:
    HopeOverMope Thanks this.
  5. blsqueak
    blsqueak Road Train Member
    Dec 27, 2009
    3,988
    Thanks Received:
    3,284
    buckeye lake, oh
    Have you tried the T/A when you get back since they are Freightliner certified. Might just be something simple like maybe a loose wire or another type of fuse link???
  6. Broccelli
    Jan 2, 2014
    373
    Thanks Received:
    198
    Virginia
    Yeah I planned on giving them a shot. I just would feel silly if there is something as simple as a fuse to change that I don't know of.
  7. scottied67
    scottied67 Road Train Member
    Mar 14, 2010
    10,826
    Thanks Received:
    12,673
    california norte
    One of my backup lights burned out. I just removed it. Nice big hole where it used to be. Unreal $135,000 dollar truck.
  8. blsqueak
    Dec 27, 2009
    3,988
    Thanks Received:
    3,284
    buckeye lake, oh
    Nothing wrong with feeling silly. There are so many parts to these trucks that we as drivers cannot really know them all. I did find out something the other day, and that this T/A can service the small DEF filter on your truck, but not mine since a KW.
  9. Chip S
    Chip S Light Load Member
    May 27, 2013
    200
    Thanks Received:
    104
    Texas
    Unfortunately there is no fuse for the reverse lights, as they are a logic controlled output from sam chassis. The switch is on top of the trans, left rear on top. You can disconnect the switch and jump it, to see if it is the switch. If not, there is either a wiring problem or an issue with the sam chassis
    Broccelli and mhyn Thank this.
  10. mandalorekiller
    mandalorekiller Light Load Member
    Oct 6, 2014
    119
    Thanks Received:
    22
    I use my utility light when backing at night while bobtailed
