Backing up, let me get this straight
Discussion in 'Experienced Truckers' Advice' started by CrabbyOlLady, Nov 5, 2012.
  1. CrabbyOlLady
    CrabbyOlLady Bobtail Member
    43
    24
    Nov 2, 2012
    Washington
    If this isn't the right forum, admin please move it. TYVM
    Search didn't bring up as much as I thought it would and I'm trying to wrap my head around backing in from all angles/blindside/alley/anything that could wind up under youtube as "dumbest driver".
    Since a rig is essentially articulated would it be more like backing in a boat on a trailer which is vastly different from a box? It seems to me after spending a couple of hours down at the tracks in our area where Sunday night is busy for Monday morning, if you want the trailer to go where its supposed to you turn the opposite direction making macro adjustments until you have it where you want it - is that somewhat accurate or way off the mark?
    I know there are a lot of variables but lets say its a standard 10 dock station, no uneven grade with 2-2½' either side once the trailer is up to the dock (yea, its a lot of room) and plenty of room to swing in the front aside from other trucks also loading/unloading. I'd come in straight, lets say have to swing in left (easier) start backing my turn with the wheels turned to the right then adjust to right to center so I'm at a slight tail left angle 1/4 of the way back then turn back to center/center right until its straight enough to macro center left.
    Does that make any sense? Hope so because drawing won't work, the crayon doesn't come off the monitor very well.
    Its something I notice and study and have also tried to practice with my 40' 5th wheel but that is with a HD truck and not very far off the ground so there is more room to adjust - not sure if that would translate over to an 18 or more but it seems like it would on a smaller scale.
    Since we used to boat all the time, the biggest mistake I would see is people would turn the direction they wanted to get the trailer and end up with it in the wrong direction, you always turned the opposite direction on start then macro correct to launch straight. The biggest difference is the 90º angle you can get with a recreational vehicle opposed to a rig, some you can, most you can't and binding up on the cap is gonna be painfully expensive.
    Any opinions and input would be helpful.
    (in case you haven't guessed, backing is my biggest rattle and apparently an old habit of using html tags is cause for editing)
    Hammerup Thanks this.
  3. NYROADIE
    NYROADIE Heavy Load Member
    773
    471
    Jun 24, 2010
    Rochester NY
    I think you've got it, but on your bout trl and camper the axles are close to the center NOT on a 18 wheeler! In a way that makes it easy and harder. You will see. Another thing and very importent! You always want to sight side back NOT blind side! Whats the diff? When you have a sleeper behind your seat that makes a HUGE blind spot, when your jacked around like that you can't see the tail end or either side of the trl! And remember Get Out And Look =GOAL
    Hammerup, Elimillsap and CrabbyOlLady Thank this.
  4. lawrencehowardjr79
    lawrencehowardjr79 Bobtail Member
    9
    Nov 5, 2012
    alabama
    easyest way my grandfather put it to me was if the trailer is goin one way an u dont want it to steer that way. small ajustments r best never over steer backing up i feel. gud luck u will get it im sure
    CrabbyOlLady Thanks this.
  5. millsjl01
    millsjl01 Light Load Member
    298
    375
    Jan 24, 2012
    Driver seat/sleeper berth
    Backing, was the hardest part to learn. Mostly because you will have a bunch of people yelling opposing suggestions to you. If you have the opportunity to get your hands on a truck (big truck) and trailer, the best advice I can offer is to practice ALONE. No one in the truck, no one outside of it, no one watching. That is what I finally had to do.
    The other main thing to remember is not to oversteer. Even being out on the road for nearly a year, I will still oversteer on occasion. Oversteering will shoot it out of the water every time, and frustrate you to the point where you wont be able to do anything except bang your head on the wheel in frustration.
    When you to get frustrated to the point where your sweating, your leg is on fire from clutching and your ready to explode with irriation and anger....STOP. Pop the breaks, sit, and THINK about what you have done so far and WHY it hasn't worked. Try something different. Get out and look, pause, think, regain your composure and start over.
    It does get easier, but backing will always be the hardest part of driving a truck, at least for me.
    EZX1100, LadyJo, chipnbugs and 3 others Thank this.
  6. Okieron
    Okieron Crusty Okie
    1,641
    1,024
    Dec 23, 2009
    muskogee, ok
    Backing is the worst part to me and I'm pretty good, but like has been said practice practice practice ! and when you think you have it down practice some more. and remember where the tandems are will change how the trailer swings. so works today may not work tomorrow. good luck
    chipnbugs, CrabbyOlLady and Hammerup Thank this.
  7. sdlm
    sdlm Light Load Member
    271
    139
    Aug 8, 2012
    I can relate to this, I couldn't stand trying to back up with my trainer telling me what to do, I couldnt get it at all. However without him I found it was quite easy.
    We approach problems in different ways, there are actually many different ways to back into most docks. The common problem is that many people think wrongly that the way they do it is the only way or the best way. If it gets in that door and nothing gets damaged that is what matters.
    In general I try to think of the angle my trailer is at, this means I prefer to get the straightest angle I can to setup from, with a straightline back being the best, but there are others who find it easier to line up for a 45 degree back even if there is room to setup a straighter angle, and that is fine.
    In general aside from that I just remember it as "turn towards the problem" so when my trailer swings out I turn towards the part swinging out, so it comes back in.
    Hammerup, chipnbugs and CrabbyOlLady Thank this.
  8. robr
    robr Bobtail Member
    The hardest part of backing up to a loading dock is having to put up with an "audience". You all know what I mean. If there is nobody around you can probably get it on a couple of tries. But if it's a busy place with a lot of people watching you, sometimes it seems like you can't back up if your life depended on it. I know it's hard to do, but you have to be able to ignore what is going on around you and just do your own thing, whether it takes you one try or twenty. Especially when I started pulling trains years ago, when I would get back to our home terminal, instead of backing or pulling in to the easiest spot to park, I would look for a more difficult spot and see if I could get the rig in there. Start doing that on a regular basis and you"ll find that out on the road some of your harder spots to get into will start coming a little easier. Just remember the biggest key is patience. Some skills don't come to you overnight, but in time with repetition and experience you will eventually catch on to it.
  9. Aireal
    Aireal Medium Load Member
    602
    326
    Aug 20, 2012
    Garden City, TX
    One of the things my husband likes to do is watch others back up, how they are going about it. You can almost see the gears turning in his head and his hands move, as he thinks about what they are doing. Mostly at truck stops, where some of the parking spaces are tight and some at weird angles. But also at docks, even if he got in fine, he will still pay alot of attention if he thinks the other dock is harder to pull into.
  10. EZX1100
    EZX1100 Road Train Member
    4,017
    5,712
    Aug 18, 2012
    backing a truck is not hard
    when i get home, i cannot seem to back the car up without taking a moment to remember what to do
    Hammer166 and Hammerup Thank this.
  11. FozzyNOK
    FozzyNOK Road Train Member
    2,482
    3,826
    Jul 18, 2007
    Oklahomistan
    Backing is not hard.. it is simply new. How hard is tying your shoe? When your momma was trying to teach you to do that, it was the hardest thing you'd ever tried to do at that time in your life.
    Backing is theory, once you grasp the theory, you can back anywhere. It's mainly a game of being able to see where the trailer is going and making corrections. Once you get down where to LOOK its just a case of steering (correcting) to get the trailer back to the desired path and keeping in there with small corrections. Looking is the key, staring is a problem.
    You'll get it eventually.
    LadyJo, chipnbugs, ship71021 and 2 others Thank this.
