Bad coax?
Discussion in 'CB Radio Forum' started by rainmakerr, Dec 28, 2013.
  1. rainmakerr
    rainmakerr Light Load Member
    100
    25
    Mar 15, 2012
    Centreville, AL
    Went to test my SWR's today and my meter registered just under 1:5 on 20, nearly 2:0 on 1 and 1:4 on 40, so I move the meter and it quits registering anything. I move it around some and still nothing, I set it down and it starts registering again. Tried it on another CB and same thing. I hook the coax back up to the radio do a radio check and get that It sounds good on their end. Hook the meter back up and same thing happens shows nothing. I am thinking that the short piece of coax that I use to connect the meter to the radio is bad, anyone have any other ideas or thoughts?
  3. KW Cajun
    KW Cajun Road Train Member
    2,383
    3,652
    Apr 12, 2013
    Copperhead Road
    Quite possible it's just a bad connection in the coax jumper.
    I'd swap that coax out first.
    Naturally, if the problem than persists, you know it would be a flaky swr meter.
    Also check & make sure there's not a battery going dead in the swr meter.
    I would think all swr meters have a small battery (possibly small hearing aid style battery), similar to ohmmeters & continuity meters.
    I have an old radio shack swr meter, but I don't have it here to look at, to see.
  4. Big_m
    Big_m Heavy Load Member
    881
    265
    Oct 13, 2009
    Central Maryland
    I also think it's just a bad connection in the coax jumper. And most SWR meters there's no battery. Powered by the radio.
    mike5511 Thanks this.
