Bad Day / Good Day
Discussion in 'Trucks [ Eighteen Wheelers ]' started by mtoo, Mar 28, 2015.
  1. mtoo
    mtoo Road Train Member
    1,942
    4,525
    Jan 15, 2011
    Retired on bended knee
    Got 2,000 pounds on the flat, headed west on I80 close to the Wy. line. All the sudden "POP" takes a second to figure out what happened. Truck is slowing down, look up there's a pull off just a few feet in front of me. Just get the trailer off the roadway and everything locks up. Jump out take a look, brake can diaphragm blew out. Grabbed a vice grip, pinched the line, pulled out out of harms way. Grab my box of brass, find a plug, take hose off insert plug. Cage the spring. I was not on the side of the road 15 mins.
    Now I wonder if it is a violation to have one parking brake caged. I have no air leaks, and all service brakes work, with correct adjustments.
  3. rollin coal
    rollin coal Road Train Member
    13,620
    27,996
    Mar 29, 2008
    TN
    Sometimes it takes longer to stop to take a whizz and you call that a bad day? Lol. Yep, it's out of service don't get caught.
  4. swaan
    swaan Road Train Member
    2,942
    4,374
    Jul 12, 2009
    BC canada
    It's not out of service. It's the parking brake not service brake. Some trucks only come with maxi brakes on one drive axle. Your fine.
  5. mtoo
    1,942
    4,525
    Jan 15, 2011
    Can you still order new trucks with maxi brakes on one axle? I should put it this way, 2003 could you still get maxi brakes on one axle? This is the first truck I've owned with them on both axles.
  6. swaan
    2,942
    4,374
    Jul 12, 2009
    BC canada
    I'm perty sure u can if you want to. Lots of cheap spec company trucks only have spring brakes on front drive axle.
    Put it this way. If your pulling a 9 axle lowbed and every wheel has spring brakes do you think it's going to matter much if one is not working.
  7. BullDoggin
    BullDoggin Light Load Member
    183
    56
    Jan 27, 2013
    doesn't caging a brake chamber render the service brake inoperable?
    wore out Thanks this.
  8. swaan
    2,942
    4,374
    Jul 12, 2009
    BC canada
    No. It renders the spring brake inoperable. Service is fine.
    Pedigreed Bulldog Thanks this.
  9. BoxCarKidd
    BoxCarKidd Road Train Member
    4,548
    6,641
    Aug 26, 2014
    Trucks with spring brakes on only one drive axle are supposed to lock the power divider when the parking brake is set to comply with the park brake on all drive axles rule. The gauged spring brake has nothing to do with service brake operation and I do not believe is out of service criteria and you may have to explain brake operation to Barney and remind him this is to get to the nearest repair facility. Barney mad, your out of service! Just be nice and remind him you still have one more parking brake than many trucks already, he probably does not know either.
  10. rollin coal
    13,620
    27,996
    Mar 29, 2008
    TN
    That's what I thought too. Just got schooled.
  11. double yellow
    5,946
    10,066
    Aug 28, 2011
    State of Jefferson
    No big deal -- 6x2 tractors only have 2 maxi brakes & they're fairly common...
