Bad DEF quality and Nox sensor ? Check engine lights but they come and go
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Sekhri, Aug 18, 2017.
  1. KB3MMX
    KB3MMX Road Train Member
    3,079
    2,596
    Dec 29, 2014
    Orrstown, PA
    You can drain, rinse with distilled water and refill... Make sure it's distilled, no other types of water...
  3. Conrad fire Equipment
    Conrad fire Equipment Bobtail Member
    I have three codes
    1 1866
    2. 3867
    3. 4277
    Fmi is showing n/a
    We have three trucks showing the same
  4. GrapeApe
    GrapeApe Road Train Member
    2,215
    2,212
    Jan 7, 2013
    I'm not sure why you posted this. Do you have a question? If so, 3 faults on an unknown truck of an unknown year with an unknown engine, won't get you many good answers. We're not mind readers, help us help you,
  5. redd trucker
    redd trucker Bobtail Member
    12
    10
    Jul 24, 2017
    Did you find out what the problem was. I think I’m having the same issue my code showing is 545 16 0 eng 0 comes and goes check it before was something about the nox sensor. 2014 Freightliner Cascadia Cummins ISX
  6. Akatainc18
    Akatainc18 Bobtail Member
    Hi I’m having a problem where I have 3 codes(spn 4811fmi 2)(spn5394fmi17)(spn3675fmi5) any help with getting this fix is welcomed.. oh and it’s on a 2012 Volvo d13 @GrapeApe
  7. CDL CPL
    CDL CPL Light Load Member
    186
    63
    Aug 14, 2017
    Iowa
    Having the same problem. You can tell the truck is derated already. Code is spn4364 fmi 2 it's a 2013 Freightliner cascadia with a dd15 engine. Any insight is much appreciated.
  8. uncleal13
    uncleal13 Road Train Member
    3,797
    6,300
    Apr 9, 2009
    Humboldt, Sk
    I have that exact same code this past winter and again these past two weeks. It comes on about 20 minutes after getting on the highway. But then clears itself several minutes later.
    I have Detroit Diagnostic Link. I ran a couple of tests and determined that my outlet NOx sensor was out of range. Should have been within 15% of the inlet NOx sensor but was 40% under. ( Low temp ATD test, and NOx conversion efficiency test).
    This weekend I changed the outlet NOx sensor ($500). I won’t know for a few days if it does the trick. I’ll let you know.
    Newto Trucking and spsauerland Thank this.
  9. uncleal13
    3,797
    6,300
    Apr 9, 2009
    Humboldt, Sk
    Nope. Didn't change a thing. Got the same code climbing a hill today.
    My DPF filter is near the end of its useful life, 92% full. I'll wait until I get it changed out in another few months and see if that's effecting it.
    Newto Trucking Thanks this.
  10. danny23tx
    danny23tx Road Train Member
    1,494
    2,324
    Feb 16, 2016
    Austin,Tx
    Yup same here . Codes come and go , now I'm having to regen more often. Quality and Nox codes.
    uncleal13 Thanks this.
  11. uncleal13
    3,797
    6,300
    Apr 9, 2009
    Humboldt, Sk
    Tomorrow I'm going to try a DOC plugged face routine. It takes about 4-1/2 hrs to run it.
    danny23tx Thanks this.
