Bad DEF quality and Nox sensor ? Check engine lights but they come and go
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Sekhri, Aug 18, 2017.
  1. simonsocm
    simonsocm Light Load Member
    111
    67
    Aug 17, 2019
    Only easy one I know of is that OTR tool.
    mwhjr1988 and shatteredsquare Thank this.
  3. shatteredsquare
    shatteredsquare Road Train Member
    1,409
    1,845
    May 23, 2014
    middle dirt
    holy crap, i just bought that muffin thing, the detroit OTR reset tool. no more derates, no more tows, forced regen as much as you want to keep that thing burned clean inside. and that way at least you can get yourself to your shop of choice for aftertreatment work if there is a legit problem. lots of sensors and components to trigger faults and depending on who you get to "diagnose" the problem, one little thing could turn into a $10k snowball right quick. now just got to figure out what software to get to look at the pressure readings and nox readings while it's running, to know what to replace when stuff starts dying
  4. Crossbones
    Crossbones Light Load Member
    115
    66
    Mar 10, 2018
    Western NC
    Same issue here. 2014 ProStar/N13 MaxxForce. SPN-3226. No performance issues, no yellow triangle or stop engine. Sometimes the check engine light comes on, sometimes it doesn't and the fault clears. No pattern to this behavior at all. Thoughts anyone?
  5. simonsocm
    111
    67
    Aug 17, 2019
    Maxxforce is know for finicky emissions issues from my understanding. Might be that it needs an update or if it happens randomly it could be that you're getting a little coolant from your EGR cooler into the system. That was my issue on my Volvo for awhile, as well as wiring getting chaffed and popping up issues during rain.
    There's so much that can go wrong on emissions trucks its kinda understandable that it is a pain to diagnose them sometimes.
