Bad weight distribution
Discussion in 'Questions From New Drivers' started by Samuelh, Oct 19, 2018.
  1. Samuelh
    Samuelh Bobtail Member
    36
    39
    Jun 23, 2018
    So i got loaded with a mix of pallets of flour sacks and the big bulk sacks
    Last load of the day for the shipper, they sealed the trailer and left. I run the 10 miles or so back to the yard to weigh it.
    Ends up being 33xxxlbs on the tandems and 31xxx on the drives with tandems all the way back. No chance of getting it reworked tonight. Weather was nice today no wind or anything so I took it the 200 miles. Pulled ok didn't feel wonky or anything on straight rural highways.
    At what point does weight distribution screw with handling? I'm guessing in slick conditions an ### heavy trailer is more likely to Jack knife?
  3. STexan
    STexan Road Train Member
    14,963
    29,160
    Oct 3, 2011
    Longview, TX
    Handling and ride is not the problem. Hitting curbs and other objects is the biggest concern running around with tandems all the way back on a 53. Then there are some states where that configuration is illegal.
  4. Oldironfan
    Oldironfan Road Train Member
    5,776
    5,544
    May 22, 2017
    I'm guessing they put single, double, single, in the nose. Than they put 2 pallets at the rear doors.
    So no way to run tandems at the 48ft and be length legal or bridge legal.
    Could you have moved 5th wheel up?
  5. x1Heavy
    x1Heavy Road Train Member
    34,016
    42,144
    Mar 5, 2016
    White County, Arkansas
    I dislike it when details are left out suchj 33,xxx Is it 33,000 flat or 33,999
    Leaving your tandems to me, old school shows a laziness. Get back up there until your tandems on the 53 are at least even with the little door hooks about 4 foot or so from the back taile lights on the trailer. (The mudflaps that is)
    This is not solved yet by any process.
    Metallica88 Thanks this.
  6. TripleSix
    133,522
    You were probably 11/31/33 with the wheels all the way to the rear. If you were 11/28/33, extremely light on the drives and almost maximum on the trailer, you would feel ‘the tail wagging the dog. Ever see a half ton pickup pulling a travel trailer, and the trailer wagging all over and the truck looking as if he wants to jackknife? Heavy trailer, light truck, and a driver who keeps sawing on the steering wheel.
    Next time you see one, pay attention to the LTL doubles and the tanker yankers. Those guys actually have to be able to drive, otherwise they will have that tail wagging.
  7. jammer910Z
    jammer910Z Road Train Member
    2,446
    6,525
    May 28, 2015
    It's my general rule that anything over 42k doesn't load past the 48ft mark.
    If they loaded that to the back door, thats the biggest issue.
  8. Rome8911
    Rome8911 Bobtail Member
    4
    How can I get that extra weight off of the steer axle I'm in Indian headed to GA I've been through one weigh station no problem but I feel like I am still in the wrong. I've only been driving a month and dont want to get a ticket because of my steer axle
  9. ZVar
    ZVar Road Train Member
    10,911
    23,833
    Sep 10, 2010
    Flint, MI
    Why bother? You are very likely legal.
    Contrary to popular belief, 12k is not the max for steers.
    There are actually three places to look for max weight.
    1. State axle max. Usually 20k, but read your atlas to verify per state.
    2. Axle weight rating. On your driver door jam
    3. Tire rating. On the tire.
    Max axle is the lesser of the three.
  10. Roguefox
    Roguefox Light Load Member
    274
    735
    Jun 18, 2013
    Slide your tandem axles towards the weight.
  11. GreenPete359
    GreenPete359 Road Train Member
    2,257
    5,435
    Oct 21, 2017
    Driving my recliner
    You’ve already burnt that weight off in fuel. Don’t even worry about it.
    Also look in the front of your motor carriers atlas, it will list the permited axle weights for all the states you’re driving thru.
    snowlauncher Thanks this.
