Ball mounts
Discussion in 'CB Radio Forum' started by Nessmuk, Sep 9, 2019.
  1. Nessmuk
    Nessmuk Bobtail Member
    28
    7
    Jul 18, 2018
    I am going to use a three magnet roof mount for a 6ft skip shooter. I need to angle it forward from the fiberglass roof extension of the sleeper cab.
    Is there any reason a ball mounts can not be mounted onto the plate of the magnet mount and work.
  3. jessejamesdallas
    1,416
    855
    Oct 3, 2008
    Republic of Texas
    nope, none whatsoever...do what ya have to do!
  4. Ridgeline
    22,727
    123,501
    Why do you have to lean it forward?
  5. Nessmuk
    28
    7
    Jul 18, 2018
    Hits the fiberglass.
  6. mike5511
    mike5511 Road Train Member
    3,156
    1,546
    May 15, 2011
    NW Arkansas
    The fiberglass probably won't bother it as far as performance goes. Stick a tennis ball on the antenna to keep from scarring up the fiberglass and run with it.
  7. speedyk
    speedyk Road Train Member
    1,837
    2,471
    Apr 8, 2015
    What color tennis ball?
  8. Powder Joints
    7,988
    8,406
    Sep 25, 2007
    Rosamond, SoCal
    Blue balls hes a trucker, they get that color from people busting them.
    mike5511 and olddog_newtricks Thank this.
  9. rabbiporkchop
    9,678
    6,545
    Feb 9, 2012
    Wapwallopen, Pa
    Define "work".
    Just because it functions somewhat doesn't mean it couldn't be 10 times better. Lifting your feed point 2" above the surface of your roof is definitely going to hurt the performance.
  10. speedyk
    1,837
    2,471
    Apr 8, 2015
    Does that happen with those spring mounts as well? Worked for a place that insisted on them to save on broken antennas.
  11. rabbiporkchop
    9,678
    6,545
    Feb 9, 2012
    Wapwallopen, Pa
    It's all about the feed point location in relationship to the flat metal surface of a roof of a car. You can add as many Springs as you want to the base of the antenna without having an adverse effect Since the RF is traveling through the Springs. Normally the feed point of the antenna would be inside the vehicle for best performance. As you elevate the feed point away from the sheet metal surface the performance degrades drastically in direct proportion to that distance.
    speedyk and Powder Joints Thank this.
