Basic Math test
Discussion in 'Questions From New Drivers' started by VATEAM, Nov 17, 2014.
  1. VATEAM
    VATEAM Bobtail Member
    45
    8
    Jun 27, 2014
    Virginia
    Should we expect a basic math test at orientation with Covenant? If so, what does it include? Can you use a calculator?
  3. AppalachianTrucker
    AppalachianTrucker Heavy Load Member
    708
    552
    May 25, 2014
    Orion Arm
    Differential equations for trucking.
    No calculators.
    Marlin46 Thanks this.
  4. Tonythetruckerdude
    Tonythetruckerdude Crusty Deer Slayer
    2,911
    55,452
    Dec 8, 2012
    hunting...../ retired
    If you have to use a calculator in solving "basic" math problems.......you've got problems already.....
  5. Gunner75
    Gunner75 Road Train Member
    5,701
    9,076
    Mar 17, 2014
    Jackson Center Ohio
    Addition, subtraction, multiplication, division, pretty sure thats what youll need to use, highly doubt youll be doing calculous, or trigonometry equations. I point towards what tony said above.
  6. mattbnr
    mattbnr Road Train Member
    1,950
    837
    Aug 19, 2010
    Tama,Iowa
    If your truck weights 13450 bobtail and the trailer weights 14,340 empty and you leave Dallas at 4am on a eastbound train and you have your headlights on how many apples does Johnny have on the trailer?
  7. VATEAM
    45
    8
    Jun 27, 2014
    Virginia
  8. Little Eddy
    Little Eddy Medium Load Member
    598
    968
    Mar 8, 2014
    A load weighing 42,595 is headed to a warehouse 1121 miles away, the load is expected in 72 hours, you have 49 on your 70 and 9.5 on your 11. The shipper tells you the load will be ready in 45 minutes but you know from experience this shipper is grossly inaccurate in their time estimates by 23%. You will need to take a route that crosses 4 passes that exceed 5000ft. The conditions are predicted to be 60% rainy for 75% of the time.
    You have 3/4 in your fuel tanks and your tires are at 100psi.
    Given this information answer the following question your driver manger is asking..."Why was your ETA off by 20 minutes 4 days ago?"
    mattbnr Thanks this.
  9. lostcauz
    lostcauz Bobtail Member
    27
    10
    Nov 10, 2014
    TN
    Looks like basic math to me.
  10. lostcauz
    27
    10
    Nov 10, 2014
    TN
    honeyandlovie, try khanacademy.org if you want a good refresher in math and many other subjects. It's a great resource.
  11. Tonythetruckerdude
    2,911
    55,452
    Dec 8, 2012
    Wasn't trolling at at , only making an observation....If simple math like most of the problems on that test you linked are above you then you'll have trouble even with a calculator. I'm 65 years old and I remember learning 90 % of that in grade school , then the rest before entering the 9th grade.
