Battery Booster Cable
Discussion in 'Ask An Owner Operator' started by swiff, Oct 19, 2014.
  1. swiff
    swiff Light Load Member
    136
    25
    Apr 22, 2014
    Can anyone recommend a good battery booster for a semi?
    I can't find the right one to buy from amazon.
    Thank you.
  3. bigkev1115
    bigkev1115 Road Train Member
    2,364
    3,619
    Oct 23, 2009
    Alexandria, AL
    I would go with the ones that say heavy duty, and they are at least 20-25 feet, and have a low gauge like a 2 or 4 gauge rating
    swiff Thanks this.
  4. Tall Mike
    Tall Mike Road Train Member
    7,830
    38,231
    Aug 20, 2014
    New York State
    swiff Thanks this.
  5. Powder Joints
    8,041
    8,515
    Sep 25, 2007
    Rosamond, SoCal
    Go to the welding supply, buy 2 sections of 00 heavey duty copper cable, 4 welding ground clamps and a Barlow Pocket Knife (because every real trucker has one). Also have them put Red heatshrink on the ends of one of the cable, or buy a can of red plastic coat and coat 2 of the clamp grips and install them (should not need to say this but....) on the same cable...
    Best jumpers you will ever have. Built mie back in 1977 and they still work great today.
    swiff Thanks this.
  6. jbatmick
    jbatmick Road Train Member
    2,200
    2,512
    Dec 1, 2009
    hastings, Fl
    I build my own using welding cable I buy. MUCH better.Buy some 2 or 4 gauge, cut them about 22 feet, buy some GOOD commercial ends, use them a few times, they get stolen or lost , repeat as needed.
    swiff Thanks this.
  7. pcfreak
    pcfreak Heavy Load Member
    835
    385
    Apr 22, 2007
    Alberta, Canada
    Try a farm supply store. Got mine there but don't recall the brand. #2 gauge and 20 feet long for over $130. Good cables are not cheap.
    swiff Thanks this.
  8. Davidlee
    Davidlee Medium Load Member
    419
    156
    Aug 31, 2012
    I have not seen a decent pair of cables in over a decade. This is a little pricey but also the best way to go. The welding cable remains flexible at lower temps. and are very rugged.
    swiff Thanks this.
  9. swiff
    136
    25
    Apr 22, 2014
    Okay thanks guys, I will look for a 2 gauge on amazon, I am way too lazy to build one like you geniuses out there. lol.
  10. leftlanetruckin
    leftlanetruckin Road Train Member
    3,607
    3,163
    Mar 12, 2009
    Mo Via Blackpool,Lancs.
    I dare say a welding place will build them for you, although "building" is a stretch IMHO. Cut wire to length, slide heat shrink over the bare ends, crimp on the clamps, slide heat shrink over the connection and heat up. Done.
    Go no thinner than 2 gauge. I'd hate to use a set of 4 gauge cables on a cold day....
    Martin
  11. Jerry12
    Jerry12 Heavy Load Member
    723
    282
    Sep 9, 2014
    Try installing Engine Start Module, (Maxwell Ultra Capacitor) ...im just saying, no cables @ -40.
